The OneAPI base and HPC toolkits have been working without problems until I recently tried to install an update for both toolkits. This appeared to work but it left the old versions in place.
I Then asked the installer to uninstall the old versions but this failed in some way and has left the installation in a state that causes the installer to fail completely. The log files are attached.
I really now believe I need to completely uninstall the toolkits and start again so I would appreciate advice on how to do this manually.
with my regards,
Brian Gladman
Hi Brian, could you please share the below details with us for further investigation.
- Operating System & It's Build number on which you need to install the product.
- Exact Product name and it's version.
- Visual Studio and it's version if installed.
- Screenshot of an error code while uninstalling the product.
HI Rahul,
I have done this in a series of private messages. I was informed on July 15th that the issue had been passed to a higher team and that you would get back to me as soon as possible. I have heard nothing since then.
Hi Brian, we have sent you a private message. Kindly check your inbox.
![](/skins/images/C4F7392A5C68ACA60290C9576F107044/responsive_peak/images/icon_anonymous_message.png)
