Hi There,
I just installed the recently released Fedora Workstation 39 (AMD x86_64). I'm trying to install Intel® oneAPI HPC Toolkit following the instructions provided by official installation guide.
I created the oneAPI repository file and added it to configuration directory /etc/yum.repos.d.
When I try to upgrade the repositories,
sudo dnf upgrade
I get the following messages:
Intel® oneAPI repository 667 B/s | 287 B 00:00
Error: Falha ao baixar os metadados do repo. 'oneAPI': repomd.xml GPG signature verification error: Error during parsing OpenPGP packets: Parsing an OpenPGP packet:
Failed to parse Signature Packet
because: Signature appears to be created by a non-conformant OpenPGP implementation, see <https://github.com/rpm-software-management/rpm/issues/2351>.
because: Malformed MPI: leading bit is not set: expected bit 8 to be set in 11011 (1b)
Ignorando repositórios: oneAPI
Última verificação de metadados: 0:37:41 atrás em qua 08 nov 2023 09:38:09.
Dependências resolvidas.
Nada para fazer.
Concluído!
(sorry for non-english messages).
I get the same messages when I try to install Intel® oneAPI HPC Toolkit without dnf upgrade:
sudo dnf install intel-hpckit
Is there a way to solve this?
Thanks!
Hi Paulo, please share the below details with us:
- Operating System build version.
- Version of Intel® oneAPI HPC Toolkit
- Other versions of Intel® Parallel Studio XE or Intel® oneAPI already installed on the system.
- Screenshots of the error screen
We would like to know.
Hi @Vipin_Singh1,
Thank you for your attention. I will attend your request although I found a solution I'll comment later.
Linux laptop 6.5.10-300.fc39.x86_64 #1 SMP PREEMPT_DYNAMIC Thu Nov 2 20:01:06 UTC 2023 x86_64 GNU/Linux
intel-hpckit x86_64 2023.2.0-49438
(current version available in Intel oneAPI repository)
Any.
Further searches led me to this discussion about oneAPI installation without gpg check.
Thus, instead of
sudo dnf upgrade
I did
sudo dnf upgrade --nogpgcheck
sudo dnf install intel-hpckit --nogpgcheck
Now the installation is finished. A simple 'hello.f90' compiled successfully.
Cheers,
Hi Paulo, thank you for your confirmation. We are glad that the issue has been resolved.
If you have any further queries, please post a new question as this thread will no longer be monitored by Intel®.
