I downloaded the bast toolkit and hpc toolkit for fortran compile (both online and offline)
When I run it, the oneAPI logo icon appears for a while and then disappears and nothing happens.
I tried the proposed work in the previous thread, but it didn't work in my case.
https://community.intel.com/t5/Intel-oneAPI-Registration/Base-Toolkit-Installer-does-not-start/m-p/1...
windows 11pro 22000.527
Microsoft Visual Studio Community 2022 (64-bit) - 17.1.0
The same symptoms were also observed on the labtop.
It is the same Windows and Visual Studio version.
Here are the toolkit versions I've tried:
w_BaseKit_p_2022.1.0.116
w_HPCKit_p_2022.1.0.93
w_BaseKit_p_2022.1.2.154
w_HPCKit_p_2022.1.2.116
w_fortran-compiler_p_2021.1.2.62_offline
w_fortran-compiler_p_2022.0.2.98_offline
Hi WJJ and Hrmazloumi,
This is a known issue. Sorry for this inconvenience it may cause. We have documented the workarounds via this link.
I hope it helps.
Ying
Same issue here!
I hope it helps.
Ying
The effect on my PC was rather devastating... I had to restore my C: drive to an earlier date. Until I did that the Intel Installer would just crash, even if I removed Visual Studio 2022 altogether.
Once I restored my system to a week ago I could proceed with OneApi on VS 17.06 and it seems OK so far... still installing.. been on 97% for 20 mins !!! I hope it eventually finishes !
Hi Jeon, our investigation has shown us that on Microsoft* Windows*, the installation of Intel® oneAPI Toolkits versions 2022.1 and 2022.1.2 and standalone components will fail using Microsoft* Visual Studio* 2022 version 17.1.x.
There are 2 possible workarounds, prior to installing an Intel® oneAPI toolkit or component:
- Uninstall Visual Studio 2022 version 17.1.x and install the older version 17.0.6 from here Visual Studio 2022 Release History | Microsoft Docs> https://docs.microsoft.com/en-us/visualstudio/releases/2022/release-history.
- Replace Microsoft.VisualStudio.Setup.Configuration.Native.dll with same dll from a Visual Studio 2022 17.0.x release. For example, from version 17.0.6 https://docs.microsoft.com/en-us/visualstudio/releases/2022/release-history
We are striving to provide a new release in the weeks ahead to address this installation issue. Please let me know if you have any questions on this.
Jeon, we are glad that the issue has been resolved.
If you have any further queries, please post a new question as this thread will no longer be monitored by Intel®.
