We are trying to install the following products onto a:
PS C:\WINDOWS\system32> [System.Environment]::OSVersion.Version
Major Minor Build Revision
10 0 19045 0
Workstation in the following order:
- w_fortran-compiler_p_2024.0.2.27_offline.exe
- w_mpi_oneapi_p_2021.11.0.49512_offline.exe
- w_onemkl_p_2024.0.0.49672_offline.exe
1 and 2 are working now, but for one or another reason we cannot install the math kernel (mkl). This is the log which doesn't tell me much:
03/13/2024 09:18:35:400 : 5016 : MESSAGE : C:\Program Files (x86)\Intel\oneAPI\Installer\installer.exe is run with arguments: --log-dir C:/Users/svc-teamcity-ansible/AppData/Local/Temp/intel_oneapi_installer/2024.03.13.09.18.28.149 --product-id intel.oneapi.win.mkl.product --product-ver 2024.0.0+49670 --package-path C:\Users\svc-teamcity-ansible\Downloads\w_onemkl_p_2024.0.0.49672_offline\packages
03/13/2024 09:18:35:400 : 5016 : MESSAGE : Installer is started in GUI mode
03/13/2024 09:18:35:401 : 5016 : MESSAGE : Installer executable location is C:\Program Files (x86)\Intel\oneAPI\Installer\installer.exe, version is 4.3.4.1166
03/13/2024 09:18:35:401 : 5016 : MESSAGE : Package manager executable location is C:\Program Files (x86)\Intel\PackageManager\1.0\packagemanager.exe, version is 4.3.4-1166
03/13/2024 09:18:35:401 : 5016 : MESSAGE : Product is set to intel.oneapi.win.mkl.product,v=2024.0.0+49670. Mode is set to install.
03/13/2024 09:18:35:769 : 10040 : MESSAGE : PreRequisite for other install successfully checked
03/13/2024 09:18:35:771 : 10040 : MESSAGE : PreRequisite for other Intel install successfully checked
03/13/2024 09:18:35:773 : 10040 : MESSAGE : All checks for preRequisite for supported operation system are passed
03/13/2024 09:18:37:928 : 10040 : MESSAGE : PreRequisite for admin rights successfully checked
03/13/2024 09:18:37:929 : 10040 : MESSAGE : PreRequisite for temporary folder successfully checked
03/13/2024 09:18:37:930 : 10040 : MESSAGE : PreRequisite for host architecture successfully checked
03/13/2024 09:18:38:023 : 5016 : MESSAGE : The following products are installed by the moment:
Id: intel.oneapi.lin.fortran-compiler.product, name: Intel® Fortran Compiler & Intel® Fortran Compiler Classic, version: 2024.0.2, installation directory: C:\Program Files (x86)\Intel\oneAPI
Id: intel.oneapi.win.mpi.product, name: Intel® MPI Library, version: 2021.11.0, installation directory: C:\Program Files (x86)\Intel\oneAPI
End of installed products list.
03/13/2024 09:18:50:217 : 5420 : MESSAGE : PreRequisite for Instance Msi successfully checked
03/13/2024 09:19:08:582 : 5420 : MESSAGE : PreRequisite for free disk space passed
03/13/2024 09:19:08:582 : 5420 : MESSAGE : PreRequisite for permissions passed
03/13/2024 09:19:08:582 : 5420 : MESSAGE : PreRequisite for other install successfully checked
03/13/2024 09:19:08:582 : 5420 : MESSAGE : PreRequisite for other Intel install successfully checked
03/13/2024 09:19:08:624 : 5016 : MESSAGE : ISIP consent status is 'No'
03/13/2024 09:19:08:624 : 5016 : MESSAGE : Product installation directory is C:\Program Files (x86)\Intel\oneAPI
03/13/2024 09:19:08:624 : 5016 : MESSAGE : Product will be (un)integrated with the following IDEs:
03/13/2024 09:19:08:625 : 5016 : MESSAGE : End of IDE list.
03/13/2024 09:19:08:654 : 5420 : MESSAGE : Graph State Dump.
intel.oneapi.win.mkl.product,v=2024.0.0+49670, Enabled, Not Selected, Not Installed
intel.oneapi.win.mkl.devel,v=2024.0.0+49670, Enabled, Not Selected, Not Installed
intel.oneapi.win.mkl.runtime,v=2024.0.0+49670, Enabled, Not Selected, Not Installed
intel.oneapi.win.oneapi-common.vars,v=2024.0.0+49430, Enabled, Not Selected, Installed
intel.oneapi.win.oneapi-common.vs2019_links,v=2024.0.0+49430, Enabled, Not Selected, Not Installed
intel.oneapi.win.oneapi-common.vs2022_links,v=2024.0.0+49430, Enabled, Not Selected, Installed
intel.oneapi.win.oneapi-common.licensing,v=2024.0.0+49430, Enabled, Not Selected, Installed
intel.oneapi.win.oneapi-common.oneapi-vars,v=2024.0.0+49430, Enabled, Not Selected, Installed
intel.oneapi.win.cpp-base-pro-common-runtime,v=2024.0.0+49846, Enabled, Not Selected, Not Installed
intel.oneapi.win.compilers-common-runtime,v=2024.0.0+49846, Disabled, Not Selected, Not Installed
intel.oneapi.win.openmp,v=2024.0.0+49846, Disabled, Not Selected, Not Installed
intel.oneapi.win.tcm,v=1.0.0+452, Enabled, Not Selected, Installed
intel.oneapi.win.tbb.runtime,v=2021.11.0+49524, Enabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.vcperflib_vsix_vs2019,v=2024.0.0+49158, Enabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.vcperflib_vsix_vs2022,v=2024.0.0+49158, Enabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.vcperflib_bt_vs2019,v=2024.0.0+49158, Enabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.vcperflib_bt_vs2022,v=2024.0.0+49158, Enabled, Not Selected, Not Installed
03/13/2024 09:19:08:693 : 5016 : MESSAGE : ----------------------------------------------------------------------------------------------------
03/13/2024 09:19:08:693 : 5016 : MESSAGE : Anonymous statistics fields:
03/13/2024 09:19:08:693 : 5016 : MESSAGE : EventId = 'install-min'
03/13/2024 09:19:08:693 : 5016 : MESSAGE : EventKey = 'S3UqiDQDs0egwqo7y1z17w=='
03/13/2024 09:19:08:693 : 5016 : MESSAGE : EventTime = ''
03/13/2024 09:19:08:693 : 5016 : MESSAGE : Id = 'intel.oneapi.win.mkl.product,v=2024.0.0+49670'
03/13/2024 09:19:08:693 : 5016 : MESSAGE : Message = '{ \"product_name\":\"[Windows] Intel® oneAPI Math Kernel Library 2024.0.0\", \"lic_type\":\"\", \"support_code\":\"\", \"install_status\":\"4611\", \"product_tag\":\"\" }'
03/13/2024 09:19:08:693 : 5016 : MESSAGE : ProductId = '[Windows] Intel® oneAPI Math Kernel Library 2024.0.0'
Can you shine some light on this ?
Hi Willem, please know that Microsoft Visual Studio is Version: 2022 17.7.5 is tested and validated by our engineering team. We have also checked, and it's perfectly working with the latest Intel® Toolkits. Microsoft Visual Studio 2019 may or may not work with Intel® oneAPI Math Kernel Library (oneMKL). We suggest you follow the recommended steps to install the product and kindly let us know if you still facing the same issue.
Hi Willem, we would like to inform you that the tested and validated Microsoft Visual Studio is Version: 2022 17.7.5 for all the latest Intel® Toolkits. Kindly follow the below troubleshooting steps to perform the installation:
- Open the Control panel and click on Uninstall a program below the Programs box.
- Find "Microsoft Visual Studio (existing versions)" then click the right button and uninstall.
- The uninstaller program will be open then click on remove and select the next procedure.
- Kindly visit the below link to find the steps with InstallCleanup.exe to make sure a Visual Studio version is completely uninstalled.
- Link: https://learn.microsoft.com/en-us/visualstudio/install/uninstall-visual-studio?view=vs-2022#remove-all-with-installcleanupexe
- Once the uninstallation is complete, we suggest you download the compatible Visual Studio version (i.e., Visual Studio 2022 17.7.5 ).
- Please note, that our engineering team has tested and documented the compatible Visual Studio versions and their build numbers for integration with the suite & toolkit versions.
- Intel® Compilers Compatibility:
- Make sure you select the 'Desktop development with C++' component while installing Visual Studio.
- Once Visual Studio 2022 Version 17.7.5 is successfully installed, you can proceed with installing Intel® oneAPI Math Kernel Library (oneMKL) Offline from the below link:
Thank you !
It seems that we had an earlier version of VS2022.
Do you know an answer for VS2019 (yes, we are still using that) ? I.e. what is the version you have checked for mkl 2024 ?
Mind that we estill have to test the combination Intel 2024 + VS2019. As VS2019 is kinda old, this might be a good reason to upgrade our software development processes to that IDE.
Hi Willem, we have sent you a private message. Kindly check your community inbox.
Hi Willem, unfortunately, we were unable to hear back from you.
If you have any further queries, please post a new question, as this thread will no longer be monitored by Intel®.
