UPDATE:
If you run into issues with the update to 2022.3 please follow these steps:
Deinstall all Visual Studio instances.
Deinstall oneAPI BaseKit 2022.1.2.
Reinstall Visual Studio 2022 version 17.1.x.
Install BaseKit 2022.1.3.
If your experiencing problems with the legacy product PSXE, please consider upgrading to oneapi, or stick with the VC version supported in PSXE release.
KNOWN ISSUE
On Microsoft* Windows*, the installation of Intel oneAPI Toolkits versions 2022.1 and 2022.1.2 and standalone components will fail using Microsoft* Visual Studio* 2022 version 17.1.x.
There are 2 possible workarounds, prior to installing an Intel oneAPI toolkit or component:
- Uninstall Visual Studio 2022 version 17.1.x and install the older version 17.0.6 from here Visual Studio 2022 Release History | Microsoft Docs.
- Replace Microsoft.VisualStudio.Setup.Configuration.Native.dll with same dll from a Visual Studi0 2022 17.0.x release. For example, from version 17.0.6 https://docs.microsoft.com/en-us/visualstudio/releases/2022/release-history
We are striving to provide a new release in the weeks ahead to address this installation issue.
As I mentioned in an earlier post, neither workaround is available for VS2022 COMMUNITY Edition, only the Pro and Enterprise Editions.
I was able to install the standalone component for Intel VTune Profiler 2022.1 by replacing the DLL as stated here:
I did not have to uninstall Visual Studio Community 2022 v17.10. The DLL was posted by an individual in this forum. Hope this helps.
Yes, thanks for your attention here, but we need a Community tier workaround.
Will there also be a fix for the Parallel Studio XE?
Same problem...
@AndreasB - If your experiencing problems with the legacy product PSXE, please consider upgrading to oneapi, or stick with the VC version supported in PSXE release.
New version was just posted live. You can find here:
https://www.intel.com/content/www/us/en/developer/tools/oneapi/base-toolkit-download.html
Please let me know if this resolves your issue.
Chris
