oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
1429 Discussions
Unable to install intel MKL2024.0.0.49672
Hong_geo
Hi I was trying to install intel MKL today and kept running erros like below:
03/15/2024 23:17:28:892 : 15344 : MESSAGE : C:\Program Files (x86)\Intel\oneAPI\Installer\installer.exe is run with arguments: --log-dir C:/Users/Hong/AppData/Local/Temp/intel_oneapi_installer/2024.03.15.23.17.06.346 --product-id intel.oneapi.win.mkl.product --product-ver 2024.0.0+49670 --package-path C:\Users\Hong\Downloads\w_onemkl_p_2024.0.0.49672_offline (1)\packages
03/15/2024 23:17:28:892 : 15344 : MESSAGE : Installer is started in GUI mode
03/15/2024 23:17:28:892 : 15344 : MESSAGE : Installer executable location is C:\Program Files (x86)\Intel\oneAPI\Installer\installer.exe, version is 4.3.4.1166
03/15/2024 23:17:28:892 : 15344 : MESSAGE : Package manager executable location is C:\Program Files (x86)\Intel\PackageManager\1.0\packagemanager.exe, version is 4.3.4-1166
03/15/2024 23:17:28:892 : 15344 : MESSAGE : Product is set to intel.oneapi.win.mkl.product,v=2024.0.0+49670. Mode is set to install.
03/15/2024 23:17:29:170 : 4832 : MESSAGE : PreRequisite for other install successfully checked
03/15/2024 23:17:29:177 : 4832 : MESSAGE : PreRequisite for other Intel install successfully checked
03/15/2024 23:17:29:178 : 4832 : MESSAGE : All checks for preRequisite for supported operation system are passed
03/15/2024 23:17:29:905 : 4832 : MESSAGE : PreRequisite for admin rights successfully checked
03/15/2024 23:17:29:905 : 4832 : MESSAGE : PreRequisite for temporary folder successfully checked
03/15/2024 23:17:29:905 : 4832 : MESSAGE : PreRequisite for host architecture successfully checked
03/15/2024 23:17:29:919 : 15344 : MESSAGE : The following products are installed by the moment:
Id: intel.oneapi.lin.fortran-compiler.product, name: Intel® Fortran Compiler & Intel® Fortran Compiler Classic, version: 2024.0.2, installation directory: C:\Program Files (x86)\Intel\oneAPI
Id: intel.oneapi.win.mpi.product, name: Intel® MPI Library, version: 2021.11.0, installation directory: C:\Program Files (x86)\Intel\oneAPI
End of installed products list.
03/15/2024 23:17:36:792 : 21132 : MESSAGE : PreRequisite for Instance Msi successfully checked
03/15/2024 23:17:48:348 : 21132 : MESSAGE : PreRequisite for free disk space passed
03/15/2024 23:17:48:349 : 21132 : MESSAGE : PreRequisite for permissions passed
03/15/2024 23:17:48:349 : 21132 : MESSAGE : PreRequisite for other install successfully checked
03/15/2024 23:17:48:349 : 21132 : MESSAGE : PreRequisite for other Intel install successfully checked
03/15/2024 23:17:48:379 : 15344 : MESSAGE : ISIP consent status is 'Yes'
03/15/2024 23:17:48:379 : 15344 : MESSAGE : Product installation directory is C:\Program Files (x86)\Intel\oneAPI
03/15/2024 23:17:48:379 : 15344 : MESSAGE : Product will be (un)integrated with the following IDEs:
03/15/2024 23:17:48:380 : 15344 : MESSAGE : End of IDE list.
03/15/2024 23:17:48:397 : 21132 : MESSAGE : Graph State Dump.
intel.oneapi.win.mkl.product,v=2024.0.0+49670, Enabled, Not Selected, Not Installed
intel.oneapi.win.mkl.devel,v=2024.0.0+49670, Enabled, Not Selected, Not Installed
intel.oneapi.win.mkl.runtime,v=2024.0.0+49670, Enabled, Not Selected, Not Installed
intel.oneapi.win.oneapi-common.vars,v=2024.0.0+49430, Enabled, Not Selected, Installed
intel.oneapi.win.oneapi-common.vs2019_links,v=2024.0.0+49430, Enabled, Not Selected, Installed
intel.oneapi.win.oneapi-common.vs2022_links,v=2024.0.0+49430, Enabled, Not Selected, Not Installed
intel.oneapi.win.oneapi-common.licensing,v=2024.0.0+49430, Enabled, Not Selected, Installed
intel.oneapi.win.oneapi-common.oneapi-vars,v=2024.0.0+49430, Enabled, Not Selected, Installed
intel.oneapi.win.cpp-base-pro-common-runtime,v=2024.0.0+49846, Enabled, Not Selected, Not Installed
intel.oneapi.win.compilers-common-runtime,v=2024.0.0+49846, Disabled, Not Selected, Not Installed
intel.oneapi.win.openmp,v=2024.0.0+49846, Disabled, Not Selected, Not Installed
intel.oneapi.win.tcm,v=1.0.0+452, Enabled, Not Selected, Installed
intel.oneapi.win.tbb.runtime,v=2021.11.0+49524, Enabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.vcperflib_vsix_vs2019,v=2024.0.0+49158, Enabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.vcperflib_vsix_vs2022,v=2024.0.0+49158, Enabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.vcperflib_bt_vs2019,v=2024.0.0+49158, Enabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.vcperflib_bt_vs2022,v=2024.0.0+49158, Enabled, Not Selected, Not Installed
Vipin_Singh1
Hi Hong, Could you please share the below details with us?
  • Version of Microsoft Visual Studio installed along with it's build version.
  • OS build on which you are installing the product.
  • Exact version of Intel® oneAPI Base toolkit or Intel® oneAPI Math Kernel Library (oneMKL) (in case you're using Stand-Alone Version).
  • Other versions of Intel® Parallel Studio XE or Intel® oneAPI already installed on the system.
  • Is the installer an online or an offline package?
  • Installation Log files.
    • The default path for a log file for a oneAPI installation is: C:\Program Files (x86)\Intel\oneAPI\logs
To assist you further, we would require these details.
Hong_geo
Hi Vipin_Singh1
I tried the VS 2019 community  and VS 2022 community. It failed for both.  My OS build is 22621.3296.  I tried the offline installer of MKL (w_onemkl_p_2024.0.0.49672_offline) and the log file is attached.
In fact, I need a MKL that is compatible with VS 2019 for compiling an open source software for my research (https://oss.deltares.nl/web/delft3d/get-started ).
They include:
Intel Fortran compiler, version 2023: w_fortran-compiler_p_2023.2.1.7_offline.exe
Intel MPI: w_mpi_oneapi_p_2021.10.0.49373_offline.exe
Intel MKL: <br/> w_onemkl_p_2023.2.0.49500_offline.exe
Specifically, the MKL has to be integrated with Visual Studio 2019.
Intel ifort runtime: <br/>w_ifort_runtime_p_2023.2.1.19.exe
I am trying to build this software on a Windows 11 Education system
(Edition Windows 11 Education Version 22H2
Installed on 2022
OS build 22621.3296
Experience Windows Feature Experience Pack 1000.22687.1000.0)
Is it still possible to get access to those versions of the above components?
Thanks so much for your help!
Vipin_Singh1
Hi Hong, please note that older versions of Intel® oneAPI Toolkits are not available publicly, only the Intel® oneAPI Toolkits and the latest products are available for download and installation.
Intel® has decided that Intel Compilers Versions: 2024.0.1 and earlier and Intel Libraries, Analysis, and AI Tools Versions: 2024.0.0 and earlier are not supported anymore. We urge users to upgrade to the latest version of Intel® developer tools. The unsupported versions do not include the latest functional and security updates. These versions are targeted to be removed after a period. We understand that this might be challenging, but it's important to note that the users with active priority support can only access older product versions.
For more information refer to the link: https://www.intel.com/content/www/us/en/developer/articles/release-notes/oneapi-supported-product-versions.htm, and scroll down to the Unsupported Product Version.
Intel® oneAPI users with active Intel Priority Support can access older versions via a secure portal you gain access to as part of your support subscription.
FAQ's Priority Support Link: https://www.intel.com/content/www/us/en/developer/get-help/faq-priority-support.html
Vipin_Singh1
Hi Hong, unfortunately, we were unable to hear back from you.
If you have any further queries, please post a new question, as this thread will no longer be monitored by Intel®.
