I installed oneAPI HPC Toolkit but when I type
> source /opt/intel/oneapi/setvars.sh
The follwing error appears
script_name=setvars.sh: Command not found.
env_vars_args=: Command not found.
config_file=: Command not found.
config_array=: Command not found.
component_array=: Command not found.
warning_tally=0: Command not found.
Unmatched '.
it worked only as a root when I worked before with parallel_studio_xe it workes normally.
How I can setvars.sh work with not type sudo?
Hi Ali_G_1,
Thanks for getting back to us with the details. Please know that you would have to install Intel® oneAPI Base Toolkit to get the full functionality of the Intel® oneAPI HPC Toolkit.
The Intel® oneAPI Base Toolkit is the foundational kit that enables developers to build, test, and deploy performance-driven, data-centric applications. While Toolkits such as Intel® oneAPI HPC Toolkit, Intel® oneAPI IoT Toolkit & Intel® oneAPI Rendering Toolkit are the Domain-Specific Toolkits that provide specialized workloads that can be used alongside the Intel® oneAPI Base Toolkit. You may visit the below link for reference.
You may visit & choose from the below link to download the product toolkit.
Download Link: https://software.intel.com/content/www/us/en/develop/tools/oneapi/base-toolkit/download.html
As for the operating system version, please know the Scientific Linux 7.9 (Nitrogen) is an unsupported version for Intel® oneAPI HPC Toolkit. We would recommend you refer to the below links to find more information on the System Requirements of the Intel® oneAPI HPC Toolkit & Intel® oneAPI Base Toolkit.
Intel® oneAPI Base Toolkit System Requirements: https://software.intel.com/content/www/us/en/develop/articles/intel-oneapi-base-toolkit-system-requi...
Intel® oneAPI HPC Toolkit System Requirements: https://software.intel.com/content/www/us/en/develop/articles/intel-oneapi-hpc-toolkit-system-requir...
Note: When we use the term unsupported, we are not saying it will not work, we are saying we have not done any validation. It may work, it may not work. However, if you run into a bug, we will not be addressing that bug unless it is replicated on a supported operating system.
Soumya
Hi Ali_G_1,
Thanks for posting your concern on the forum. Please let us know the below details.
- What is the version of Intel® oneAPI HPC Toolkit installed? Is it 2021.3?
- Have you installed Intel® oneAPI Base Toolkit (same version) successfully prior to the installation of Intel® oneAPI HPC Toolkit?
- The operating system name and version.
The information would allow us to assist you better.
Soumya
Hi Soumya,
I installed the following version l_HPCKit_p_2021.3.0.3230_offline.sh
I installed only the version l_HPCKit_p_2021.3.0.3230_offline.sh
NAME="Scientific Linux"
VERSION="7.9 (Nitrogen)"
ID="scientific"
ID_LIKE="rhel centos fedora"
VERSION_ID="7.9"
Hi Ali_G_1,
Soumya
Okay, which version with the fedora is supported.
Hi Ali_G_1,
The Fedora* 31 is a supported target operating system version for Intel® oneAPI Base Toolkit & Intel® oneAPI HPC Toolkit, from the Fedora family. However, there are certain limitations for which we are providing the below links for your reference. Please go through them before proceeding further.
Soumya
Hi Ali_G_1,
Please let us know if there are any further concerns.
Soumya
Hi Ali_G_1,
Thanks for getting back to us with the update on the post. As per your response, we are closing this thread. However, if you need any additional information, please feel free to post a new question as this thread will no longer be monitored by Intel®. Have a nice day ahead.
Soumya
