Analyzers
5248 Обсуждение
About vTune(GUI) Config Analysis value
gray_heron
Начинающий
3 021Просмотр.
Hi
I want to run vTune(CUI) using vTune(GUI) settings.Is the contents of Configure Analysis of vTune(GUI) saved in a file?
0 баллов
1 Решение
JyothisV_Intel
Сотрудник
2 943Просмотр.
Good day to you.
The settings for any analysis whether it be pre-defined, or custom is present inside the result directory where the collection results were saved. (If you hover over the result folder created inside Intel VTune Profiler (GUI)'s left pane or right click on it, you can view/copy the result directory as shown in screenshot). There is a sub-directory called config inside the result directory. This contains a file with the name context_values.cfg which lists out all the configuration values of the analysis in XML format. (Refer screenshot)
Hope this helps. If this resolves your issue, make sure to accept this as a solution. This would help others with similar issues.
Thanks and Regards,
Jyothis V James
Просмотреть решение в исходном сообщении
4 Ответы
VaradJ_Intel
Сотрудник
2 990Просмотр.
Good day to you.
If you want to run vTune(CUI) using vTune(GUI) settings. You can follow the below step:
1. Configure the analysis with which you want to profile your application.
2. Click on the command line option (Highlighted in the screenshot below)
3. You will get the command line code for your analysis type (check the below screenshot)
4. You can run Vtune CLI using those commands
Thank You!
gray_heron
Начинающий
2 971Просмотр.
Hi,VaradJ-san
Thank you for your reply.
I understand what the command line is. For example, the following command line is displayed when performing custom analysis.
In which file are the settings (uarch-exploration-0) saved?
"C:\Program Files (x86)\Intel\oneAPI\vtune\latest\bin64\vtune" -collect uarch-exploration-0 --app-working-dir=/root/intel/vtune/samples/matrix -- /root/intel/vtune/samples/matrix/matrix
Thank You.
JyothisV_Intel
Сотрудник
2 944Просмотр.
Good day to you.
Thanks and Regards,
Jyothis V James
JyothisV_Intel
Сотрудник
2 933Просмотр.
Thanks for accepting the solution.
Since your queries are resolved, we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
Jyothis V James
Ответить
