Analyzers
5247 討論
Amplifier hangs when any analysis is started (Linux)
Matthias_Kretz
新貢獻者 I
674 檢視
whenever I start an analysis in VTune, the GUI hangs and I have to kill it. On the other hand I can copy the command line and run it from a Terminal without problem. Opening the result via the GUI is also no problem.
Any ideas what's wrong?
PS: Product version is build 186533 (Parallel Studio SP1 Installer, downloaded today - my previous install always hung at resolving libc)
0 積分
1 解決方案
Peter_W_Intel
員工
674 檢視
I heardsimilar problem from others.
If you have no problem to run command line, and open result.
Pleasereference this KB.
Hope it helps
Regards, Peter
在原始文章中檢視解決方案
2 回應
Peter_W_Intel
員工
675 檢視
Hope it helps
Regards, Peter
Matthias_Kretz
新貢獻者 I
674 檢視
As I noted in the article, I was able to make it work by deleting only the ~/intel/amplxe/settings/settings/standalone_gui/propertyPageData.cfg file.
Thanks for the pointer!
回覆
