Analyzers
BSOD on Windows 7 using Amplifier 2015 Update 1
AndrewC
New Contributor III
I am getting a 100% repeatable BSOD on Windows 7 running Amplifier 2015 Update 1 (build 380310), native code.
Advanced Hotspots ->Hotspots -> NO PROBLEM
Advanced Hotspots ->Hotspots , stacks and context switches ->BSOD after a few seconds.
Suggestions?
AndrewC
New Contributor III
PM sent with FTP link
Stanislav_B_Intel1
@vasci_
Would you please run a sort of reversed experiment: enable call stacks, but disable context switches?
We need to see the picture from different angles. Thanks!
Bernard
Valued Contributor I
@vasci_ , @Peter Wang
I suppose that this piece of x64 assembly code could be a culprit of the BugCheck 0x101. It seems like some kind of spin-wait loop on variable  which is executed by the machine code shown below. This is CPU #7 which is running Solver.exe process threads.Thread fffffa8024f41060 is in running state with RIP pointing to vtss+0x11691 (fffff882`1065d691 4885c0          test    rax,rax) instruction which is performing spin-wait loop. Could this be a cuse of CPU6 hang?
6: kd> u @rip
vtss+0x11691:
fffff882`1065d694 75f2            jne     vtss+0x11688 (fffff882`1065d688)
fffff882`1065d696 f0480fbaab8800000000 lock bts qword ptr [rbx+88h],0
fffff882`1065d6a0 738c            jae     vtss+0x1162e (fffff882`1065d62e)
fffff882`1065d6a2 ebe4            jmp     vtss+0x11688 (fffff882`1065d688)
fffff882`1065d6a4 4032ff          xor     dil,dil
fffff882`1065d6a7 ebb2            jmp     vtss+0x1165b (fffff882`1065d65b)
fffff882`1065d6a9 488bc4          mov     rax,rsp
6: kd> ub @rip+16
vtss+0x11688:
fffff882`1065d688 f390            pause
fffff882`1065d68a 488b8388000000  mov     rax,qword ptr [rbx+88h]
Peter_W_Intel
@iliyapolak
I have forwarded your investigating result to the developer. Thank you.
AndrewC
New Contributor III
PM send with link to new .DMP
Bernard
@Peter
Here is complete analysis of VTune BugCheck 0x101.
Bernard
@Peter
Do you have any info regarding BugCheck 0x101?
Peter_W_Intel
@iliyapolak
Thank you for data, but it is under investigating. I will update news if any process.
Bernard
Thanks for updating.
Peter_W_Intel
See similar issue in this thread to get fixed vtss.sys and know *steps*, in last page.
Let me know if you still have this problem after upgrading to 2016 U2 with fixed vtss.sys. Thank you.
AndrewC
New Contributor III
Things are working for me just fine now!
Peter_W_Intel
@ vasci_
I'm glad to know this, and thank you for quick response.
