Since the release notes of Intel VTune Performance Analyzer 9.1 doesn't talk about supporting applications written using OPENmpi 1.3 libraries on Linux, I want to know if it is officially supported.
Thanks for your time.
Quoting - anandb
Supposing that you run the MPI application under VTune, you will expect VTune to collect events associate only with the copies of the application running on the same node as VTune.
Quoting - anandb
Both sampling data collection and call graph data collection can profile OpenMP* based application.
Regards, Peter
Quoting - Peter Wang (Intel)
Regards, Peter
Peter is right, in that even a hybrid OpenMP/MPI execution could be profiled by sampling. Call graph might best be limited to a single MPI process, using the CLI version of VTune running inside mpirun.
Topic Options
