I am getting an "Error 255" before Inspector seems to perform any memory analysis on my C program. I am doing a static compile with C and some Fortran mixed in (icc and ifort) but the same failure happens when I compile dynamically. The error I get is rather cryptic and I can't find the description of Error 255 in documentation. I'm quoting the log file below. Is there something wrong with my program's compile settings? Valgrind runs on it. Thanks!
David
<?xml version="1.0" encoding="UTF-8"?>
<feedback>
<message severity="info">Memory error analysis: started</message>
<nop/>
<message severity="info">Result file: [/home/david/intel/inspxe/projects/OccBC$
<nop/>
<message severity="error">An internal error has occurred. Our apologies for th$
<nop/>
<message severity="info">Application exit code: [255] </message>
<nop/>
<nop/>
<nop/>
<message severity="info">Memory error analysis: terminated</message>
<nop/>
</feedback>
![](/skins/images/98E68944C1FF703B8AC50091329B92AF/responsive_peak/images/icon_anonymous_message.png)
