Analyzers
5284 Discussions
Hot spot analysis about video coding
fei__xing_h
Hi,I am using vtune amplifier to analyze coding efficiency about video encoding. I found the most consuming code is arithmetic coding module. In “Caller/Callee” tab, I double click the function of the core arithmetic coding which is called frequently, the time consuming of this function is showed. My question is, when the most time consuming code line is the function name line, what’s the meaning?vtune-arithmetic-intel.jpg
Peter_W_Intel
Usually it was due to compiler's issue...compiler will generate optimized code sequence for performance consideration, that didn't match original source code's order. You can click on one source line then click "Assembly" button in source view of VTune, it will display assembly code for corresponding source line.
TimP
You may need options such as /debug:inline-debug-info
Bernard
Valued Contributor I
As @Peter said you should look at corresponding disassembled code of encoding function. Regarding the most time consumption line of code maybe it could accumulated wait time for the resources.
Bernard
>>>Regarding the most time consumption line of code maybe it could accumulated wait time for the resources.>>>
@coolfat
You can check it by looking at Front-End stalls.
