Analyzers
5247 Discussions
How to change disassembly flavor from AT&T to Intel style
Lin_L_Intel
Vtune shows asm code in AT&T but the code in manual is in Intel style. It sometimes confuses me for different operand orders especially for complex instructions. Could anyone kindly tell me how to change AT&T to Intel style in Vtune?
Vitaly_S_Intel
Click on the 3-line button in the right top corner of VTune UI and choose Options. In Source/Assembly tab there is a configuration for assembler syntax options.
Vitaly_S_Intel
Lin_L_Intel
Hi Slobodskoy, thanks for your response. I tried your suggestion, (both GAS and MASM), but nothing changed. It doesn't work.
By the way, I just use vtune to view collected results, without creating a new project. I'm not sure if this will cause any problems.
Lin_L_Intel
Actually it works. The software needs restart to enable the effect.
