Analyzers
NUM_PHYSICAL_CPUS
malo
I have vtune RDC 9.0 build 1478 on linux debian 4.0 x86_64. vtune gui runs on winxp 9.0 build 719. when I'm trying to configure sampling activity (on a remote host) it returnsthe following error message
Failed to create Collector:
Could not get NUM_PHYSICAL_CPUS value from environment XML file.
any idea?
thanks
malo
log from vtserver:
vtlistenerd: 03/25/08 12:43:26 -- Remote Agent --------------
vtlistenerd: 03/25/08 12:43:26 server version: v9.0
vtlistenerd: 03/25/08 12:43:32 Incoming connection request: Session Id: XXXXX.217-1360, User_Id: XXXX, Client IP: XXX.194 Arch: , Version: vt 9.0, protocol version 0.0
vtlistenerd: 03/25/08 12:43:32 Connection accepted
000 03/25/2008 12:43:33 15861 -- Sampling Collector --------
000 03/25/2008 12:43:33 15861 driver version: v0.9495
000 03/25/2008 12:43:33 15861 library version: v0.879
Ravi_V_Intel
Please download the latest version of VTune and the associated RDC. Please use the RDC from the same release as the VTune Windows Controlling machine. If you can still reproduce the issue, please post a note here.
