Analyzers
PMU resource(s) currently being used by another profiling tool or process
Asimina_M_
초급자
839 조회수
I would please your help with the following. We are using intel vtune on a cluster. I submit two different jobs that collect hardware counters  on two different nodes/boxes on our cluster. The first job runs okay, the second fails with the error   "Error: PMU resource(s) currently being used by another profiling tool or process." Now thse are two difffrened nodes on the cluster so I could not think why hardware counters cannot be used at the same time for two different jobs.
Is there a problem with installation or a vtune issue?Can anything be doen to resolve this?
Thanks a lot,
M
0 포인트
2 응답
Peter_W_Intel
직원
839 조회수
Maybe you need to check if other software (which uses PMU resource) is running, for example - perf.
Also, you may check vtune drivers installed or not:
lsmod | grep sep
lsmod | grep pax
lsmod | grep vtsspp
0 포인트
Dmitry_P_Intel1
839 조회수
Could you please provide VTune command line that you used for the both nodes?
Thanks & Regards, Dmitry
0 포인트
응답
