Analyzers
5281 Discussions
Problem in analysing the results
eretailtech
I have attached some screen shots after which I am unable to understand what to do and how to proceed with test results. Awaiting your comments.
Peter_W_Intel
You can use menu item "FileExport..." to pop up a dialog, please specify file name and path that you want to save, "All" is for all displayed contents in the view (processes report, threads report, modules report, hotspots report), "Selection" is for the selection in the view, especially for source view.
eretailtech
but i want to know where is problem in my EXE which i am testing so i can understand that the diff... what i have to chnage
Peter_W_Intel
Quoting - eretailtech
For sampling data collection, modify the activity and keep event named CPU_CLK_UNHALTED.CORE only - thus, after runing sampling, the result will display "Most Active Functions In Your Application" which diaply hot functions in your module, and elapse time. Then you can doubl-click to narrow down to hot source lines.
Regards, Peter
