Analyzers
5255 Discussions
TSX sampling of aborts fails
Oliver_K_
I was able to collect data of TSX sampling (option '1. Transactionl success') - but if I select option '2. Aborts' Vtune gives me an error:
Error 0x40000024 (No data) no data is collected ...
I use the same binary (application using TSX) for both cases. Why is Vtune unable to collect data for TSX aborts?
Oliver
Roman_D_Intel
probably there were too few aborts happened (VTune record data only once per X events - this is sampling). Try to decrease the "sample after value" or make your workload run longer.
Roman
Oliver_K_
ty Roman - reducing the threshold helped
