Analyzers
5247 Discussões
Unable to use "Cycles and uOps" analysis
Mandar_Gurav
Principiante
1.345 Visualizações
I am unable to run "Cycles and uOps" analysis under Sandy Bridge / Ivy Bridge / Haswell Analysis. It says - This analysis type is only defined for the processors based on the intel microarchitecture code name Sandy Bridge / Ivy Bridge.
I am running vtune as administrator and "Run as Administrator". System details are
Product version: Update 5 (build 274450)
OS: Windows server 2008 R2 standard Service Pack 1
Processor : intel i5-3570 @ 3.4 GHz - Turbo boost disabled
Memory: 8GB
Can anyone help me on this?
7 Respostas
David_A_Intel1
Funcionário
1.345 Visualizações
Hi:
Are you able to run General Exploration and/or Lightweight-Hotspots on the system?
Mandar_Gurav
Principiante
1.345 Visualizações
Yes both analysis I can run.
Under "Sandy Bridge / Ivy Bridge / Haswell Analysis" It gives the same error message for "Branch Analysis" Others in this group don't have this problem.
Thank you.
LLess
Principiante
1.345 Visualizações
I have the same issue here I7 3770K Windows 7 X64.
VTune Amplifier XE 2013 Update 5 (Build 274450).
Laurent.
salec83_s_
Principiante
1.345 Visualizações
Tested
Peter_W_Intel
Funcionário
1.345 Visualizações
I just tried this problem in the system, "Windows Server 2008 R2 Enterprise SP1" with Intel(R) Core(TM) i7-2600K CPU 3.40 GHz,
I cannot reproduce this problem.
1. (Assume that your account has "administrator" privilege) Ran cmd as administrator
2.  VTune Amplifier XE 2013\amplxe-vars.bat
3. amplxe-cl -version ; showed Update 6 (build283589)
4. amplxe-cl -collect-list; should see "snb-cycles-uops" event
5. amplxe-cl -collect snb-cycles-uops -duration 10; it worked
Mandar_Gurav
Principiante
1.345 Visualizações
Can we run this via GUI mode?
I reported this issue to intel premier support. They could reproduce this issue and confirmed it. But, we are still stuck.
Peter_W_Intel
Funcionário
1.345 Visualizações
Mandar Gurav wrote:
Absolutely I can run this on GUI.
It is great that you communicated with support engineer via Intel Premier, since you can provide more system info with log file by using amplxe-feedback. Also you can query the progress on Intel Premier.
Responder
