Analyzers
5341 Discussions
Update linux kernel breaks advisor 17 update 4
Timocafé
We did an update of our RHEL kernel from (RHEL 6.8) kernel 2.6.32-642.6.2.el6.x86_64 to (RHEL 6.9) 2.6.32-696.3.2.el6.x86_64.
Using the last version of advisor update 4
ewart@bbpviz2 ~]$ advixe-cl  --version
Intel(R) Advisor Command Line Tool
Copyright (C) 2009-2017 Intel Corporation. All rights reserved.
Intel(R) Advisor 2017 Update 4 (build 517067) Command Line Tool
We get the following error message on a hello word.
[ewart@bbpviz036 learning_engine]$  advixe-cl -collect survey ./a.out
advixe: Collection started. To stop the collection, either press CTRL-C or enter from another console window: advixe-cl -r /gpfs/bbp.cscs.ch/home/ewart/learning_engine/e000/hs001 -command stop.
advixe: Collection stopped.
advixe: Warning: The application returned a non-zero exit value.
advixe: Opening result 31 % Processing profile metrics and debug information
advixe: Error: Error 0x4000002a (Database interface error) -- Cannot run data transformation `Add Fake Loop Data'.
advixe: Opening result 99 % done
advixe: Opening result 100 % done
advixe: Error: Data loading failed.
advixe: Error: Unknown error during finalization
Alexandra_S_Intel
Looks like you may be having a pin problem (we're seeing a lot of them right now). Can you run pin on an executable?
Timocafé
Thank you for the help.
[ewart@bbpviz036 ~]$ pin -- ./a.out
Bus error (core dumped)
a.out is a simple hello word
Tom_R_
I'm having the same problem with a program that does some loop calculations.
Same error using pin also:
$ pin -- ./a.out
Tom_R_
I was having the problem with a larger C program.  I was able to run vtune with that program, but got this error running advisor 2017 update 2.
Ronald_G_1
Hello Intel.   Is there a workaround or fix to this?
I'm seeing the same issue with the 2018 Advisor XE, 4.11.4-1.el7.elrepo.x86_64
