Analyzers
5298 Discussions
pin.exe The NTDLL!NtMapViewOfSection function jumps out of NTDLL
Paul_H_
We are having a problem running Advisor, following advise found elsewhere we are trying to run this command to prove pin.exe works and getting the error below. Can anyone offer some assistance on how we go about resolving this. This is Parallel Studio XE 2018 on Windows 7 with VS2017.
thanks
pin.exe -- notepad
E: SYSCALL_INSPECTOR: The NTDLL!NtMapViewOfSection function jumps out of NTDLL, at 0x027480000. It may be hooked by a PIN-incompatible software instal
led on the system
A: Source\pin\base_w\ipc_server_windows.cpp: LEVEL_BASE::StartServer: 2216: assertion failed: res == TRUE
NO STACK TRACE AVAILABLE
Kevin_O_Intel1
We are currently creating a product update that resolves this issue. This should be create shortly.
Paul_H_
Thanks, do you have any more accurate timescales? We have just started a trial for evaluation so time is ticking on the 30days and this has stopped us proceeding.
thanks
Paul
Kevin_O_Intel1
Paul,
I am having one of our business development managers contact you directly. They can extend your trial license.
Kevin
