Analyzers
5017 Discussions
V Tune not showing P-core untilisation on Microarchitecture Exploration
oliver_h
For some reason the P-Core data is not showing on my 12900k on the matrix example.
I'm using V-Tune straight "out of the box" just running the example program as shown. However, in Threading it does show that all 16 (physical) cores are being being targeted as well as saying that on the console when using the example.
I have used V-Tune on my laptop which is also alderlake and cannot replicate the error.
Could there be a security feature stopping the drivers from being able to see the cpu event counters soemwhere?
Dom324
JaideepK_Intel
Hi @Dom324 ,
Good day to you.
Can you please keep the screenshot of the HyperV status?
Jaideep
JaideepK_Intel
Sorry for the delay.
Can you all please try to run the same analysis with the latest version of VTune Profiler (2023)?
We were able to see p-core metrics.
Jaideep
JaideepK_Intel
Hi All,
The above issue is resolved in the latest version of Vtune.
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue. Thank you!
Jaideep
Maximillia_D_Intel
Hi Jaideep,
  Issue seems to be fixed. I confirmed I still saw the issue on 2022.4.0 build 624343.
I downloaded 2023.0.0 build 624757 and installed it. It seems to work.
I now see P core events. I can accept the solution. I intend to use Vtune some more for my work and glad to see it able to record those events.
Max
JaideepK_Intel
Hi @oliver_h ,
Good day to you.
We assume your issue is resolved. Can we close this case?
Jaideep
Maximillia_D_Intel
Yes. Please close the case. Thanks!
I have some new ones to file and will do so on another post.
Max
JaideepK_Intel
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jaideep
