Analyzers
VTune crash report crashes Outlook Win7
jimdempseyatthecove
This morning I woke up my system to be greeted with a notification from VTune that it had crashed. It asked to send the crash report. Clicking Send, crashed (hung - not responding) Outlook (Office 2010). Couldn't the VTune dialog box, nor Outlook. Had to use TaskManager to kill Outlook.
Jim Dempsey
Bernard
Valued Contributor I
Can you post crash data from the event viewer?
jimdempseyatthecove
I do not see anything specific in the Event Viewer relating to Visual Studio or VTune.
Around that time I see entries like:
The application-specific permission settings do not grant Local Activation permission for the COM Server application with CLSID
{B77C4C36-0154-4C52-AB49-FAA03837E47F}
and APPID
{EA022610-0748-4C24-B229-6C507EBDFDBB}
to the user i72600K\Jim SID (S-1-5-21-2439415982-1773311800-1471933187-1000) from address LocalHost (Using LRPC). This security permission can be modified using the Component Services administrative tool.
The server was unable to allocate from the system nonpaged pool because the server reached the configured limit for nonpaged pool allocations.
The description for Event ID 1002 from source Visual Studio 2010 Remote Debugger cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
The remote debugger is unable to communicate with Visual Studio, and must abort the remote debugging session. Please restart debugging.
The program OUTLOOK.EXE version 14.0.7113.5000 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Action Center control panel.
Process ID: ca8
Start Time: 01cf9d2c760888b0
Termination Time: 61
Application Path: C:\Program Files (x86)\Microsoft Office\Office14\OUTLOOK.EXE
Report Id: 06fba08c-17e2-11e4-acf2-f46d0449b7ad
** to which I had to terminate with Task Manager
Jim Dempsey
Bernard
I expected  to see access violation type of crash. I suppose that in your case something different has happend.
