Analyzers
5279 讨论
VTune profiler sampling driver setup issue
Highlander
新手
5,722 次查看
I installed VTune and I checked out the article about sampling driver setup.
I executed the command for driver setup in PS and the output says that driver is ok, but:
  • I did it from 64 bit dir because there is no such program in 32 bit dir;
  • the VTune is keeping complaining about lack of sampling driver.
How can I fix it?
I attached the screens:
  • VTune complains about lack of sampling driver;
  • Successful driver status via tool from 64 bit folder;
  • Failed attempts to launch tool from 32 bit folder.
It seems like I did something wrong but I didn't find any similar issue via google.
0 项奖励
1 解答
Highlander
新手
5,674 次查看
I'm feeling dumb right now.
I started the gui app from PS and it worked fine.
Then I tried to launch the app as I usually do but as admin and it works.
So I needed to launch it as administrator to fix the issue.
Thanks for the help and have a nice day!
在原帖中查看解决方案
7 回复数
Kirill_U_Intel
5,704 次查看
64-bit version is enough. 32-bit is for 32-bit OS-s.
Could you run 'VTUNE_DIR/bin64/sep -version'? What is output?
Could you restart VTune and try collection again?
Thanks, Kirill
0 项奖励
Highlander
新手
5,695 次查看
Hello Kirill
I did what you said and attached a picture of output.
VTune restart didn't help, I tried it for a few times.
I hope that you'll help me with this
0 项奖励
Kirill_U_Intel
5,691 次查看
Hm, 'sep -version' output is fine.
Could you try VTUNE_DIR\bin64\amplxe-runss.exe --context-value-list? Pls, attached output here.
and could you run ' VTUNE_DIR\bin64\sep -start -d 3'? is it ok? is it dumped *.tb7 file?
Are both VTune and console run by the same user?
Kirill
0 项奖励
Highlander
新手
5,680 次查看
I attached the output for the first command.
The second command dumped *.tb7 file. I've loaded it into VTune and it seems like it's ok(screens attached).
0 项奖励
Kirill_U_Intel
5,676 次查看
I'm confused. All is fine.
Could you launch VTune from console where you run sep tool? Is the error message again?
Could you change 'performance snapshot' on 'hardware hotspots', for example?
Kirill
0 项奖励
Highlander
新手
5,675 次查看
JananiC_Intel
主持人
5,652 次查看
Glad to know that your issue got resolved.We would no longer be monitoring this issue.Please raise a new thread incase of any further issues.
0 项奖励
回复
