Community
cancel
Showing results for
Search instead for
Did you mean:
Black Belt
VTune: restricting counting to user mode generated events
Jump to solution
Linux perf posses an option an "u" switch to restrict the event counting to user mode code triggers only. Does VTune (its console version) posses a corresponding switch to enable only user mode performance event counting?
I thoroughly inspected the available command line switches and have not seen that option existing.
Thank you
Accepted Solutions
It is possible with a custom analysis type that you can compose yourself (-collect-with action in CL) or derive from a predefined analysis type using GUI and then generate a command line from it. In the custom analysis type you can add "-knob event-mode=user" to collect only user mode samples.
Thanks & Regards, Dmitry
Black Belt
Hi Dmitry,
Thank you very much.
That was the answer that I was looking for.
Hi iliyapolak,
Glad to know that your issue is resolved. We won't be monitoring this thread anymore. Kindly raise a new thread if you need further assistance.
Arun
