Analyzers
5253 Discussions
Vtune cannot collect data in windows 11
chrysalisX
My machine has win11 and linux system installed. I installed vtune on both system, but win11 vtune cannot collect any data from programs, even the sample program from vtune.
Problem:
Vtune cannot collect any data from programs in win 11. including sample project.
Environment:
 win 11
Things I have tried:
  1. install vtune in same machine under linux -> fixed this problem, but I need to optimize a windows application.
  2. run application in hotspost mode and by administrator -> no use.
  3. resolve sample result -> success. so the problem is not collecting data.
  4. run application until it ends -> no use.
AlekhyaV_Intel
Thank you for posting in Intel Communities. We have tried the in-built Matrix sample and we couldn't reproduce your issue in VTune 2023.1 version. We could see all the metrics. Please refer the below screenshot.
To triage your issue further, could you please provide the below details so that we can debug your issue further?
  1. VTune version
  2. Your PC System requirements
  3. Sample reproducer - Your application, steps to compile, etc.
We could also suggest you to try uninstalling and re-installing VTune Profiler and see if the issue persists. Please update us.
Alekhya
chrysalisX
Thanks for your reply.
I noticed that vtune think my system is windows 10. But my computer setting says it is win 11 home edition (chinese mainland special edition). Maybe that is the problem? As for hardware, my laptop is yoga 14sIHU 2021.
Vtune Version: 2023.1.0
PC system info in Vtune:
Collection and Platform Info
Application Command Line: C:\Users\Lenovo\Documents\VTune\Samples\matrix\matrix.exe
Operating System: Microsoft Windows 10
Computer Name: DESKTOP-VVV8QBK
Result Size: 3.5 MB
Collection start time: 02:34:20 28/06/2023 UTC
Collection stop time: 02:34:23 28/06/2023 UTC
Collector Type: User-mode sampling and tracing
Finalization mode: Fast. If the number of collected samples exceeds the threshold, this mode limits the number of processed samples to speed up post-processing.
CPU
Name: Intel(R) microarchitecture code named Tigerlake
Frequency: 3.1 GHz
Logical CPU Count: 8
Cache Allocation Technology
Level 2 capability: available
Level 3 capability: not detected
PC system info from settings:
Windows 11 家庭中文版
22H2
2023/‎2/‎19
22621.1848
Windows Feature Experience Pack 1000.22642.1000.0
sample reproducer:
The original matrix sample exe in vtune install direction.
chrysalisX
And I have tried uninstall & install again, it does not work.
AlekhyaV_Intel
Thanks for sharing your observations with us. We are working on this internally. We will get back to you soon with an update. Meanwhile, could you please run the command line analysis and let us know the results. You could get VTune commands from here(https://www.intel.com/content/www/us/en/docs/vtune-profiler/user-guide/2023-0/command-syntax.html) Please let us know if you're facing any difficulties while running command line analysis.
Alekhya
AlekhyaV_Intel
We apologize for the delay caused. We have a couple of questions from the dev team regarding your query.
Dev team couldn't reproduce your issue in the exact infrastructure of yours. Please answer the below queries so that we can debug your issue form our end:
  1. Do you an antivirus that could be causing a problem, or any other non-default settings?
  2. Were you able to run the matrix sample outside the VTune App.
Please try the below things and get back to us:
  1. Run a system-wide analysis.
  2. Run hotspots with user-mode sampling with the "Show Additional Performance Insights" unchecked. This should prevent it from using hardware events and help narrow down the problem.
Alekhya
AlekhyaV_Intel
We have not heard back from you. Could you please give us an update regarding this issue?
Alekhya
AlekhyaV_Intel
We have not heard back from you, so we will close this thread now. If you need any further information please post a new question as this thread will no longer be monitored by Intel.
Alekhya
