Analyzers
Where is the = menu button
David_M_17
I wanted to try to refinalize my results after updating source directories.    I clicked on the ? button in the gui to get directions.   The directions say to select a particular icon on the gui menu.   I can not find that icon.  I am attaching a screenshot which shows captures the VTune view as well as the help documentation.   The background window is the gui (without the specified icon), the front window is the VTune documentation showing the icon I should be looking for (and failing to find).
(sorry if resolution is poor - I had to adjust image to allow upload to this forum).
James_S
Hi David,
Which VTune version are you using? The menu button is at the top-right, and if you cannot find the menu, you can just right click the analysis result, and select "re-solve and open" or "resolve" if you have opened that result.  Thanks.
Zhuowei
