Analyzers
5251 讨论
how to see C++ source code,only"disassembly only" button can be invoked
azaonline
初学者
1,043 次查看
I use vtune 9.1.0 in Fedora 7. My C++project is compiled by ICC. I want to see hotspots with its C++ sourcecode, but I can only see disassembly code.whether I can see C++ source code when select "display hotspots for selected item"? how can I do this? Whether vtune only support C source code?
0 项奖励
1 解答
TimP
名誉分销商 III
1,043 次查看
Quoting - azaonline
The compilation must include -g option. In that case, if VTune analyzer doesn't find the source file, it should pop up a window asking for the path. It could get complicated if your source is spread among several directories, particularly if you have set ipo.
在原帖中查看解决方案
0 项奖励
3 回复数
TimP
名誉分销商 III
1,044 次查看
Quoting - azaonline
0 项奖励
azaonline
初学者
1,043 次查看
Quoting - tim18
done! thanks a lot!
0 项奖励
TimP
名誉分销商 III
1,043 次查看
I should have reminded that -g sets -O0 when no -O is given, so it is usual to specify the desired level, such as -O2, when building for VTune.
0 项奖励
回复
