Analyzers
no call stack information #2
Marián__VooDooMan__M
New Contributor II
Greetings,
I am running i7 Haswell architecture and I don't see "call stack information" in analysis as I had for Core2 in VTune.
Am I doing something wrong, or this architecture simply doesn't support this in hardware counters?
My config: Win 8.1 x64, project c++0x x64, ICC 14 SP1 update 2, VTune the latest to date.
Bernard
Valued Contributor I
Maybe your code has inlined functions?
New Contributor II
Yes, indeed, and IPO is AFAIK inline-ing functions where it is possible.
New Contributor II
Though ICC will NOT inline functions if there are inline specifications, when the inlineing will be counter-productive.
New Contributor II
I mean the case when I use VTuune inside of MSVC 2013 integration. I get for my Haswell few analysis, but in GUI there are no "collect stacks",
New Contributor II
I mean before running the program.
Bernard
Try to disable optimization and rerun the VTune.
I do not think if resolving function calls could be dependend on specifc CPU counters.
Peter_W_Intel
My comments are:
1. If you are using general-exploration analysis and want to see call stack info, you have to add option "-knob enable-stack-collect=true". This is not a default enabled option.
2. You can use optimization, but read this article.
New Contributor II
@Peter Wang (Intel)
re 1. ICC is complaining about "/Qknob enable-stack-collect=true" being obsolete and will be removed in future
re 2. I need IPO optimization
The problem is, when I was on Core2 platform, in IDE's VTune GUI I could hit check box "collect stacks". Now I am on i7 Haswell, and I cannot do such thing. I worked around the problem by copying "advanced hostspots" to "custom analysis", and then I have option to collect stack. Inline'd functions are okay for me (when collecting stack informations).
But this is a bit tricky, I wish I could do it in IDE easily, without creating new custom analysis.
New Contributor II
Maybe a feature request...?
Peter_W_Intel
There are check boxes for "collect stack" on GUI, my box is Haswell processor. Are you using latest VTune Amplifier XE 2013 Update 16?
New Contributor II
nevermind, I have just noticed it collects stack by default.
Another problem is, "advanced hotspots" analysis stops collecting hardware events after exactly 70 seconds. In the GUI the time counter stops increasing and button to mark timeline is inactive. When the process exits, there is only first 70 seconds to examine.
Peter_W_Intel
Collecting stack is not default option, when you start a new analysis, for example, advanced-hotspots.
Collector will stop if you set Duration. Otherwise Collector will stop only the process exits.
David_A_Intel1
But I do think the option is "sticky."  Once you select stacks in Advanced Hotspots and run a collection, the next time you open up the Advanced Hotspots analysis type, stacks will be selected.  FWIW ;)
New Contributor II
But where I can enable such option? I always do "Advanced Hotspots", whether I  do or not optimization/ilining, I get an error without stack information.
PS:: I am attaching VTune conf.459509459509
Peter_W_Intel
Using option "-knob collection-detail=stack-sampling" for advanced-hotspots analysis.
Using option "-g -O0" to disable inline function, or using "-O2 -g -inline-debug-info" enables inline function and keep symbol info (function name in report).
