During installation of Intel Inspector XE 2011 Update 7 on openSUSE 12.1 KDE (64bit) I have got the following error message:
Intel Inspector XE 2011 Update 7: Cannot detect gtk library
and
Intel Inspector XE 2011 Update 7: The install program cannot detect a gtk
library on the system. The graphical user interface of the product requires gtk
version 2.4 or higher. Contact your system administrator to install a compliant
version of gtk or install the product on a compliant system.
Any hints or recomendation how to solve this issue?
and
After the installation I have got the following Warning message when I launch the inspxe-gui from the command line:
(inspxe-gui:14279): Gtk-WARNING **: /opt/intel/inspector_xe_2011/bin64/../lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib64/gtk-2.0/2.10.0/engines/liboxygen-gtk.so)
Is that only minor warning or any serious trouble?
Michal,
This forum post looks similar tohttp://software.intel.com/en-us/forums/showthread.php?t=102403. Let us know if this post is uniquely
different from the other.
Rob
Yes, there are different, because each post correspond to the different product (Inspector and Amplifier).
Of course, these posts looks very similar.
Michal
Michal
Hi Michal,
As Mark correctly mentioned in Amplifier-related thread, this warning may also signal some cosmetic changes in GUI in Inspector XE GUI.
Igor.
Yes, my apologies. I should have been more specific. My inquiry was more along the lines of determining
if the behavior was different between the products in a way that would indicate a different root
cause or unique situation.
-Rob
nice information to tell thanks
