Analyzers
"-collect-with runsa -knob event-config" only works with Basic Performance Tuning Events
John_Z_
For example
event-config=CPU_CLK_UNHALTED.THREAD
works fine. But for many others such as MEM_UNCORE_RETIRED.REMOTE_DRAM
amplxe-cl will give error like:
amplxe: Error: Cannot configure sampling event groups. The collection is terminated.
Could anyone help? Thanks
Peter_W_Intel
What VTune(TM) Amplifier XE 2015 version do you use?
I don't know your platform, please don't run PMU event-based sampling on guest Linux* operation system on Virtual Machine. And, check if you your desired event(s) can be supported on your platform, for example - run:
amplxe-runss -event-list|grep UNCORE
As I know many OFFCORE_RESPONSE.* can be supported, and events with prefix "UNCORE" is not supported on my side.
John_Z_
vtune version is vtune_amplifier_xe_2015_update4
It is not VM. OS is centos.
CPU: Intel(R) Xeon(R) CPU E5-2470 v2 @ 2.40GHz
And "/opt/intel/vtune_amplifier_xe/bin64/amplxe-runss -event-list" gives nothing in output. Thanks
Peter_W_Intel
This is interesting! I downloaded U4 and I can reproduce this problem. (It works until U3 version)
I will submit this issue to developer. As a workaround, you can use amplxe-gui to create a project, start a new analysis, right-click on "advanced hotspots", Copy from here->Add Events will display all supported event list. See attached screen shot.
Dmitry_P_Intel1
Hello John,
The event MEM_UNCORE_RETIRED.REMOTE_DRAM is actual for Nehalem-based architecture (XEON 5500) and  E5-2470 v2 that you pointed is Ivy Bridge based processor so I'm afraid you will not be able to collect the event on it.
Thanks & Regards, Dmitry
John_Z_
Peter, Thanks!
However I can not use GUI in target system. Is there any other workaround?
Dmitry, the problem is no events are available, as "-event-list" does not show anything.
Peter_W_Intel
@ John
Dmitry told me that using "/opt/intel/vtune_amplifier_xe_2015/bin64/sep -el" is another workaround to know supported events.
Dmitry_P_Intel1
Hello John,
amplxe-runss -event-list was undocumented internal feature and it is not supported in the latest updates, and yes it is possible to use "sep -e" for the list of core events and again this is for internal pusposes.
Again - the event you pointed is not available on newer Ivy Bridge-based Xeon processors. BTW - complete event lists are available in Inel Software Developmet manual matetials https://www-ssl.intel.com/content/dam/www/public/us/en/documents/manuals/64-ia-32-architectures-software-developer-manual-325462.pdf Chapter 19, table 19.4.1 for your Intel(R) Xeon(R) CPU E5-2470 v2 processor.
