Analyzers
5255 Discussions
"run as administrator" question
dougf
When attempting to run, the following message appeared: "Error. Accurate CPU time detection was disabled. Administrative privileges are required."
Is there a way to run the tool if I am on a business network where administrator access is strictly limited to a select few IT folks?
Mark_D_Intel
The collection should still run even without administrative priviledges, just with less accurate CPU time numbers.
You can removed the message by turning off this option in the GUI by unchecking 'Collect highly accurate CPU time', or by adding the option '-knob accurate-cpu-time-detection=false' to the command line.
dougf
Thanks. One further thing: now I'm getting an error "could not find ClientIntC function in the tool". Any idea what is causing this?
Kirill_R_Intel
This is a known issue. It was recently reported and designers are working on the fix. This problem is environment-specific. Meanwhile you can try to re-install the product. Running it on a different machine should help also. And this problem occurs with user mode sampling only, EBS analysis will work.
