I am running advixe-cl for the first time. If I just type
advixe-cl ... where ... are the arguments
the program hangs and nothing comes out. If I type
sudo advixe-cl ...
It works, but only when I put in the sudo password.
If I type su and then the superuser password it also works.
Now if I type advixe-gui as a normal user only a small screen title Intel Threading Assistant opens
, but nothing else happens. It completely open up if I type sudo advixe-gui and the the sudo password or
if I type su and the superuer password.
Now what is going on here?
I am attaching a snapshot of the files after a ls -al command. They all
all root root. So must i be root to run advixe-cl,-gui?
I installed eval version as root; it was recommended.
Any help appreciated. Thanks in advance.
Newport_j
![](/skins/images/D2683F18326913BBA0436CB7114DD569/responsive_peak/images/icon_anonymous_message.png)
