Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
DMA example Arria 10 PAC
AIvan11
新手
3,892 次查看
I am trying to run DMA example from the OPAE samples on Arria 10. I managed to run other examples such as nlb and hello_afu, but dma_afu example gives me following error:
Running test in HW mode Error fpgaDmaOpen: no memory Error fpgaDmaClose: invalid parameter
Can you help me resolve it. Thank you.
0 项奖励
1 解答
FawazJ_Altera
员工
2,150 次查看
Can you confirm if you have sufficient memory allocated with the following command.
sudo sh -c "echo 20 > /sys/kernel/mm/hugepages/hugepages-\ 2048kB/nr_hugepages"
Also, if you are using multiple PAC cards, you need to allocate more memory.
thanks
在原帖中查看解决方案
6 回复数
FawazJ_Altera
员工
2,150 次查看
I am still investigating the source of this error.
I will reply to you shortly.
0 项奖励
Richard_C_Intel
2,150 次查看
Which version of OPAE are you running? Which OS?
0 项奖励
AIvan11
新手
2,150 次查看
I use OPAE 1.1 on Ubuntu 18.04 server.
0 项奖励
FawazJ_Altera
员工
2,151 次查看
thanks
ashishkkaul
新分销商 I
1,985 次查看
Folks,
What was the solution to this issue? I am having the same problem. From this ticket, it is not clear how the issue got resolved?
Ofcourse, I am unable to run in sudo mode.
s005-n002:~/A10_RTL_AFU/dma_afu/sw$ sudo sh -c "echo 20 > /sys/kernel/mm/hugepages/hugepages-\ 2048kB/nr_hugepages"
Dear User,
this server does not allow you to run "sudo".
If you need to install a dependency, please put it in your home directory.
* For autotools, you can do it with "./configure --prefix=~/my-path"
* For Python packages, use "pip install <package_name> --user" or create a Conda environment.
0 项奖励
ashishkkaul
新分销商 I
1,971 次查看
@AIvan11 @FawazJ_Altera @Richard_C_Intel
How was this issue resolved? I am having the same problem.
0 项奖励
回复
