Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
504 Discussions
I want to send input to the USB port of the cyclone(FPGA) board with altera. Is there a megafunction applicable to altera?
TKoed
I want to send / receive data from the host PC (Linux) to the FPGA board (Cyclone) using a USB cable.
Both the host PC and FPGA board have USB ports.
I am currently using Quartus Prime Standard Edition 17.1.
How can I change the value that Quartus Prime sent data from the host PC (Linux) to the FPGA board?
How should I set the FPGA side to receive as input?
Can I send data from the FPGA side to the host PC via the USB cable?
system architecture
raspberry pi == usb2.0 == usb male-male cable == usb2.0 == FPGA board
MEIYAN_L_Intel
May I know that do you have install USB driver on Linux? If no, there is a document that can help you to install the USB driver on Linux:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_usb_blstr.pdf
For more information about Programmer tool in Quartus, you can refer to the document as below;
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qps-programmer.pdf
This link can also help you to understand the procedure in program FPGA board:
https://forums.intel.com/s/question/0D50P00004Sk2DB/i-want-to-send-input-to-the-usb-port-of-the-cyclonefpga-board-with-altera-is-there-a-megafunction-applicable-to-altera
