Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
LDPC throughput performance
MABLE
As of now I have done l1 and testmac in FlexRAN 22.03 using PAC N3000 card as per an912 document and the tests are successful.
I wanted to test LDPC testcases for throughput with variable base-graph(BG) and code rate(k/n).
The command which is provided in my previous query is
./l2.sh --testfile=icelake-sp/icxsp_mu0_10mhz_4x4_hton.cfg
is about running same test case multiple times and gets the throughput(ie. as per my understanding).
Please guide me through how can I change the BG and coderate and verify the  throughput as per attached image.
Also I wanted to take out the FEC processed data from PAC card to external device directly through the the ethernet ports available on card. How can I do it?
Thanks in advance,
Mable George
