Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
504 Discussions
Stratix10 Hello_world hanging
NPund
I followed all the steps specified by Terasic for the device 1SG280HU2F50E2V).
Flashed the top.sdf in user region and is successfully identified by aocl diagnose.
but when I try to do
aocl program acl0 hello_worl.aocx, It gets stuck while programming.
I checked the kernel module code and its getting stuck in while loop
In aclpci_pr.c
 // Wait for PR complete
 status = ioread32(aclpci->bar[ACL_PRCONTROLLER_BAR]+ACL_PRCONTROLLER_OFFSET+ALT_PR_CSR_OFST);
 ACL_DEBUG (KERN_DEBUG "ALT_PR_CSR_OFST status is 0x%08X", (int) status);
 while(status != ALT_PR_CSR_STATUS_PR_SUCCESS)
  msleep(100);
I checked the dmesg It is showing this error code.
dmesg output
[ 219.116119] aclpci_pr (185):
[ 219.116123] ALT_PR_CSR_OFST status is 0x00000004
[ 219.116127] aclpci_pr (190):
[ 219.116129] Size of PR RBF is 0x00C5D000
[ 244.460182] aclpci_pr (208):
[ 244.460185] Number of 4K chunks written: 3165
[ 244.460188] aclpci_pr (209):
[ 244.460190] Number of bytes in PR bitstream remaining: 0
[ 244.460196] aclpci_pr (235):
[ 244.460198] ALT_PR_CSR_OFST status is 0x00000008
[ 244.568183] aclpci_pr (240):
[ 244.568187] ALT_PR_CSR_OFST status is 0x00000008
[ 244.676183] aclpci_pr (240):
[ 244.676188] ALT_PR_CSR_OFST status is 0x00000008
I removed while loop and recompiled kernel module so that module doesn't hang but I don't understand what is the problem here while programming the PR.
FawazJ_Altera
I will investigate your request and let you know my feedback.
In the mean time, may I know which BSP did you use?
Did you do any customization?
NPund
These are the details;
OS - Ubuntu 16.04 LTS
BSP - DE10-Pro (1SG280HU2F50E2V) BSP for Intel OpenCL 18.1.1 provided by Terasic on their website.
aocl version - aocl 18.1.2.277 (Intel(R) FPGA SDK for OpenCL(TM), Version 18.1.2 Build 277 Pro Edition, Copyright (C) 2019 Intel Corporation)
Quartus Prime Pro version - Quartus Prime Version 18.1.2 Build 277 02/12/2019 SJ Pro Edition
And No I didn't do any customization.
I also tried to compile the aocx hello_world file from scratch. I got this error from aoc
Error (119013): Current license file does not support the 1SG280HU2F50E2VG device. Go to the Self-Service Licensing Center on the Intel FPGA website to manage your licenses (https://mysupport.altera.com/AlteraLicensing/license/index.html).
Error: Quartus Prime Fitter was unsuccessful. 1 error, 1 warning
Error (23035): Tcl error:
Error (23031): Evaluation of Tcl script compile_script.tcl unsuccessful
Error: Quartus Prime Compiler Database Interface was unsuccessful. 2 errors, 0 warnings
Error: Compiler Error, not able to generate hardware
Even though I have Quartus Prime Pro license.
FawazJ_Altera
it seems like a licensing issue.
Is your License valid for Quartus Pro version?
NPund
Yes, I have Quartus Pro license. But don't know if it supports all Stratix10 devices, which technically it should right?
I also contacted the licensing team, they said to seek help from the forum.
NPund
