Developing Games on Intel Graphics
If you are gaming on graphics integrated in your Intel Processor, this is the place for you! Find answers to your questions or post your issues with PC games
Blender - crash with OpenGL selection
Antony_Riakiotakis
We have an issue in blender that looks like it's caused by the Intel driver.
The report is at:
https://developer.blender.org/T43713
And the reporter provides a file to reproduce the issue.
Graphics card is HD4600
Any build from builder.blender.org might have the issue though we have been unable to reproduce it with our dev team.
Below is a picture that should show how to reproduce the issue after opening the provided in the report file.
Aaron_C_
# Blender 2.74 (sub 0), Commit date: 2015-03-14 01:10, Hash 3824e0f1
bpy.ops.object.select_all(action='TOGGLE')  # Operator
# backtrace
31: PyInit_mathutils_noise_types - 0xA9ABA140
30: fftw_plan_many_dft - 0xA8E447B0
29: fftw_plan_many_dft - 0xA8E447B0
28: fftw_plan_many_dft - 0xA8E447B0
27: UnhandledExceptionFilter - 0x332A8DD4
26: swscanf_s - 0x361DD3DC
25: _C_specific_handler - 0x36166FE8
24: RtlLookupFunctionEntry - 0x361661D0
23: DbgPrint - 0x3616727C
22: KiUserExceptionDispatcher - 0x36154B4C
21: DrvSetLayerPaletteEntries - 0x8014D0B0
20: RegisterProcTableCallback - 0x800095C0
19: DrvSetLayerPaletteEntries - 0x8014D0B0
18: fftw_plan_many_dft - 0xA8E447B0
17: fftw_plan_many_dft - 0xA8E447B0
16: fftw_plan_many_dft - 0xA8E447B0
15: fftw_plan_many_dft - 0xA8E447B0
14: fftw_plan_many_dft - 0xA8E447B0
13: fftw_plan_many_dft - 0xA8E447B0
12: fftw_plan_many_dft - 0xA8E447B0
11: fftw_plan_many_dft - 0xA8E447B0
10: fftw_plan_many_dft - 0xA8E447B0
2: osl_trunc_vv - 0xAB2D47E0
1: BaseThreadInitThunk - 0x35651828
0: RtlUserThreadStart - 0x3618F9B0
Aaron_C_
as for the dump
Aaron_C_
Antony_Riakiotakis
This doesn't look like the driver. If this is the backtrace generated by blender, which was added a few days back btw, then I'm not really sure if it's accurate (or even present) on a release build, you might want to try a debug build - we can help provide one. But probably the dump can help make things clearer here.
Aaron_C_
I used a fresh build from buildbot that i downloaded i believe yesterday git hash: 3824e0f1
Bernard
Valued Contributor I
Calls from line #3 to line #18 looks like a recursive function calls. Is that by design?
Bernard
# backtrace
Does this call stack belong to failed process?
Antony_Riakiotakis
I'm getting the exact same thing by causing a crash in a different place. I'll fix the crash report handler but for now don't treat this as reliable information please.
Antony_Riakiotakis
Here is a debug build of blender that should display a correct backtrace, but it probably needs debug libraries of MSVC 2013 to work
https://drive.google.com/file/d/0B5CLsFk4D9wHYUZnWWtKVUdPYVk/view?usp=sharing
Bernard
What is the purpose of fftw_plan_many_dft function? Judging by the function name it is somehow related to DFT transform.
Antony_Riakiotakis
It is from the FFTW library that blender uses for composited waves and the audio system. I don't know why its in the backtrace always, but as I explained I have good reason to believe it is not related to the real issue.
Aaron_C_
Getting a hold of the .dlls like we talked about on irc would be great so that I could test unless you can find a setup that crashes.
Bernard
The best option for getting correct call stack if possible is to run Blender under windbg with break in any exception settings enabled. Hopefully windbg will be able to catch the error.
Bernard
It seems that fftw function was called by os_trunc_vv. Just guessing by looking at backtrace.
Antony_Riakiotakis
I don't have an Intel card here. The only way to get a correct stack is to make have Aaron run the debug build or have someone from intel reproduce the issue with the provided build and file.
Bernard
Later I will look at crash file uploaded by Aaron.
Aaron_C_
any news?
Bernard
I was busy last few days, so I will take a look at that dump file tomorrow.
Aaron_C_
sorry for keep "bugging" /no pun intended\ you but any news ?
Bernard
Sorry for delay I was quite busy.
Will post my findings soon.
Malcolm_M_
I've just installed blender 2.7.4 on a new machine, Windows 8.1, Radeon R7, OpenGL Version 6.14.10. It's using the bundled Python
As soon as I try an OpenGL render, even of the default scene, Blender crashes out with exactly this stack trace (except for the hex addresses) in blender,crash.txt.
It reports EXCEPTION_ACCESS_VIOLATION on the console.
I've installed the latest graphics driver.
