Edge Software Catalog
478 Discussions
Question about Smart Edge Open deployment
Kevin-Tseng
Hi All!
I'm a newcomer to Smart Edge Open and currently trying to deploy Smart Edge on a server.
I'm following the approach of burning a USB on the provisioning system and then deploying it to the target system.
The official guide I'm referencing is as follows:
https://intelsmartedge.github.io/docs/experience-kits/developer-experience-kit-default-install/#overview
However, during deployment on the target system, while running the installation process on uOS, I encountered an issue.
"AttributeError: module 'importlib_metadata' has no attribute 'EntryPoints'
make: *** [Makefile:12: install-dependencies] Error 1"
After rebooting into the system, I tried running the following command inside /opt/seo :
$sudo pipenv run ./deploy.py and encounter the same error.KevinTseng_0-1747733946146.png
Here is my target system's spec:
  • Intel Xeon Silver 4210R*2
  • 64 GB RAM
  • 1TB SSD
Here is my provisioning system's environmet:
  • Ubuntu 20.04.6 LTS Desktop
  • Python 3.8
  • Docker 28.1.1
  • Docker-compose 2.24.6
I'm currently stuck at this point. Could anyone advise me on how to resolve this issue?
Thanks in advance for your help!
Zulkifli_Intel
Hi Kevin-Tseng
Thank you for reaching out.
The Smart Edge product has been discontinued and is no longer being maintained. Please refer to the DISCONTINUATION OF PROJECT.
We encourage you to use one of these:
Edge Orchestrator
Edge Microvisor Toolkit Standalone Node
Zul
Edge
Zulkifli_Intel
Hi Kevin-Tseng
Edge Orchestrator
Zul
Edge
Zulkifli_Intel
This thread will no longer be monitored since we have provided an alternative. If you need any additional information from Intel, please submit a new question.
