Edge Software Catalog
488 Discussions
Ros2 topic <any subcommand> returns invalid command error
ChrisMatthieu
I just installed the latest Robotics SDK on Windows 11 WSL2 running Ubuntu.  Everything seemed to install correctly.
I ran:
source /opt/ros/humble/setup.bash
ros2 topic list
and got the following error:
usage: ros2 [-h] [--use-python-default-buffering] Call `ros2 <command> -h` for more detailed usage. ...
ros2: error: argument Call `ros2 <command> -h` for more detailed usage.: invalid choice: 'topic' (choose from 'control', 'daemon', 'extension_points', 'extensions', 'node', 'param', 'pkg', 'run', 'service')
When I run: ros2 -h
Returns:
ros2 is an extensible command-line tool for ROS 2.
options:
-h, --help show this help message and exit
Do not force line buffering in stdout and instead use the python default buffering, which
might be affected by PYTHONUNBUFFERED/-u and depends on whatever stdout is interactive or not
Commands:
control Various control related sub-commands
daemon Various daemon related sub-commands
node Various node related sub-commands
param Various param related sub-commands
pkg Various package related sub-commands
run Run a package specific executable
service Various service related sub-commands
Notice: There is no topic listed in available commands.
Have you seen this error before?  No matter what subcommand (even pub) that I issue ros2 topic, ros complains that the command topic is invalid.
ChrisMatthieu
I reinstalled ros humble and my issue is now resolved.
ChrisMatthieu
ros2 launch commands returns the same error.
ChrisMatthieu
Turtlesim runs fine but still cannot run ros2 topic list on another window.
Same error:
ros2 topic list
ChrisMatthieu
Iffa_Intel
Glad to know that your issue is solved.
Intel will no longer monitor this thread. If you need any additional information from Intel, please submit a new question.
Cordially,
Iffa
