Edge Software Catalog
471 ディスカッション
[Ubuntu 18.04][APL] Cannot install EIS 2.3.1 successfully
davidla1
従業員
1,420件の閲覧回数
OS: Ubuntu 18.04
Platform: APL
Kernel: Reproduced on both 4.14.93-rt53 and 4.1, 5.4.0-45-generic
I run "./edgesoftware install", and it was doing fine until the waiting one hour after installed OpenVino successfully. However, it stops due to some error.
Then, I install EIS 2.3.1 by run ./edgesoftware install" again, it shows error of Failed to update apt list. Exiting installation as below log.
I run "./edgesoftware uninstall -a" and "./edgesoftware install" again, the error is same.
Can you help me out?
Starting the setup...
ESB CLI version: 2020.3
Target OS: Ubuntu
[sudo] password for ubuntu:
------------------SOFTWARE INFO-------------------
Operating System: Ubuntu 18.04.4 LTS
Kernel: 5.4.0-45-generic
------------------HARDWARE INFO-------------------
Hardware Architecture: x86_64
Processor: Intel(R) Atom(TM) Processor E3950 @ 1.60GHz
Memory size: 7.6G
Total disk space (GB): 57
Free disk space (GB): 37
---------------HARDWARE ACCELERATOR---------------
No hardware accelerator found
Python version: 3.6.9
Checking Internet connection
Connected to the Internet
Checking for prerequisites
E: The repository 'https://repo.mongodb.org/apt/ubuntu bionic/mongodb-org/4.0 Release' does not have a Release file.
E: The repository 'https://download.docker.com/linux/ubuntu bionic Release' does not have a Release file.
Failed to update apt list. Exiting installation.
ubuntu@EIS-TSN-1:~/EIS/edge_insights_industrial$
David Lai
IOTG PMCE ICE Taiwan
I am working to enable a demo of EIS + TSN for Taiwan customer.
ラベル(1)
0 件の賞賛
1 返信
Murni_J_Intel
モデレーター
1,395件の閲覧回数
Hi @davidla1
can you help to try run below comamnd ?
sudo sed -i 's|docker.com/linux/debian|docker.com/linux/ubuntu|g' /etc/apt/sources.list
sudo apt update
after done, try to run ./edgesoftware install command again.
返信
