Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
906 Discussions
Intel Ethernet Server Adapter I210 100BASE-TX ANSI 9.1.9 Jitter
AStoj1
Hi Carlos
I am measuring to high jitter value on your PCIE server adapter.
Do you have any known issues? Is there any Errata document of this adapter or of the I210-AT?
Thanks in advance
Andrija
CarlosAM_INTEL
Hello, Andrija:
In order to be on the same page, could you please confirm if the affected device is the stated in the document at the following website?
https://www.intel.com/content/dam/www/public/us/en/documents/product-briefs/ethernet-server-adapter-i210.pdf https://www.intel.com/content/dam/www/public/us/en/documents/product-briefs/ethernet-server-adapter-i210.pdf
Waiting for your reply.
Carlos_A.
AStoj1
Hi Carlos
Yes it is this Ethernet Server Adapter I210.
Andrija
CarlosAM_INTEL
Hello, Andrija:
Thanks for your reply.
The consultations related to the cited product should be addressed to the https://communities.intel.com/community/tech/wired Intel Wired Ethernet Forum .
We hope that this information may help you.
Carlos_A.
AStoj1
Hi Carlos
I wrote to Inter Wired Ethernet Forum:
https://communities.intel.com/thread/129240 Intel Ethernet Server Adapter I210 100BASE-TX A... |Intel Communities
Andrija
CarlosAM_INTEL
Hello, Andrija :
Thanks for your update.
We are glad that the proper channel is working to help you as you may notice at the following communication:
Please do not hesitate to contact us if you have any consultation related to Intel Embedded products.
We will be more than glad to help you.
Carlos_A.
AStoj1
Hi Carlos
Do you have any Errata Document for I210-AT?
Is there any known issue with this IC on the physical level?
This product here:
https://www.intel.de/content/www/de/de/embedded/products/networking/i210-ethernet-controller-family-brief.html Intel® Ethernet Controller I210 Enhances Network Connectivity
Thanks for your quick reply
Andrija
CarlosAM_INTEL
Hello, Andrija:
We suggest you address your consultations of the cited Intel networking adapter to the proper channel listed on our previous message.
However, the requested information is stated in the Specification Clarification 1, Specification Changes 3 and 4, the errata 9, 10, 12, 18, 25, 30, 33, 34, 36; and Software Clarification sections; on pages 12, 15, 16, 20, 21, 23, 24, 26, 27, 29, 30, 31, and 32 of the https://www.intel.com/content/dam/www/public/us/en/documents/specification-updates/i210-ethernet-controller-spec-update.pdf Intel(R) Ethernet Controller I210: Specification Update document # 332763.
We hope that this communication may help you.
Carlos_A.
AStoj1
Hi Carlos
Thanks for the latest Errata Document!
But I can't find anything related to my question about Jitter and 100Base-TX.
Did you measure the Jitter values of I210-AT on your Ethernet Server Adapter?
Can you provide me any document, where you perform IEEE compliance testing with I210-AT?
E.g. like this here: http://ww1.microchip.com/downloads/en/AppNotes/AN2686-Ethernet-Compliance-Test-10BASET-100BASETX-1000BASET.pdf http://ww1.microchip.com/downloads/en/AppNotes/AN2686-Ethernet-Compliance-Test-10BASET-100BASETX-1000BASET.pdf
Andrija
CarlosAM_INTEL
Hello, Andrija :
We suggest you follow our suggestion stated in our communication of this thread, specifically the one of the past September 21st, 2018; 8:23 AM, because at the cited channel you may find the proper information related to your Intel Server Adapter.
Carlos_A.
AStoj1
Hi Carlos,
I am measuring high jitter values also on other modules with I210-AT.
Do you have other information related to that?
Thanks Andrija
CarlosAM_INTEL
Hello, Andrija :
In order to better help you, could you please give us the information of all the modules that you are measuring?
Carlos_A.
AStoj1
Hi Carlos,
your Server Adapter I210 and my modules with I210-AT.
Can you check, if these register setting are correct:
https://communities.intel.com/thread/125378 Ethernet Compliance Test I210-AT 10Base-T/100Ba... |Intel Communities
How do you perform your compliance tests? Do you perform any compliance tests?
Could you please answer one of this question?
Thanks Andrija
CarlosAM_INTEL
Hello, Andrija :
In order to be on the same page, could you please explain what you are seeing as "high jitter"? Could please let us know what are the jitter values? Could you please tell us if it is a simple test, or you are seeing usability issues?
Waiting for your answer to these questions.
Carlos_A.
AStoj1
Hi Carlos
The problem is that I can't generate a continuous MLT-3 random signal or a pattern which is continuous.
Now I am only able to generate packets with your I210-AT.
Can you please check my Register Settings and tell me what I have to change to have a continuous random MLT-3 signal? Is this possible with your I210-AT?
Thanks Andrija
CarlosAM_INTEL
Hello, Andrija:
Based on the provided information, could you please let us know if the affected project has an Intel CPU?
Waiting for your answer to this question.
Carlos_A.
AStoj1
CarlosAM_INTEL
Hello, Andrija:
In case that you are using an Intel CPU, Lanconf is available and can do IEEE transmit jitter tests. But in this case, Intel has no tools for doing this test, unfortunately.
We hope that this information may clarify your questions.
Carlos_A.
AStoj1
Hi Carlos
Could you please provide me the source code, only the part where you implement the IEEE tests with register settings?
So I can check and compare it with and adopt it.
Is the random MLT-3 stream continuous with your Lanconf-Tool? Can you please check that quickly?
Thanks for your help
Andrija
CarlosAM_INTEL
Hello, Andrija :
It is important to let you know that the jitter test runs continuously until ESC is pressed.
By the way, unfortunately, there is no code available.
Carlos_A.
AStoj1
Hi Carlos
For sure the test is running continuously.
But my question is regarding the random MLT-3 signal: Is that signal continuous or bundled in packages?
Instead of the code, do you have access to the Register Setting?
Thanks Andrija
