Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
851 Discussions
WG82574ITSLBAC alternative
Donato
Hello everyone.
I'm looking for an alternative for the WG82574ITSLBAC  which is now obsolete.
Is out there available a component with the same functional charateristics? maybe improved too?
Or the closest component now available on the market.
Mechanic is not important, we will modify the gerber.
Thanks and regards,
Donato
Caguicla_Intel
Hello Donato,
Upon checking, it looks like you already raise this query last ‎09-08-2021 link below.
WG82574ITSLBAC obsolescence
https://community.intel.com/t5/Ethernet-Products/WG82574ITSLBAC-obsolescence/m-p/1312965#M26499
Here is our answer last ‎09-13-2021
Based on PCN117376-02, the recommended replacement Product Code is WGI210IT. This is still in production and not yet discontinued.
You may check this link for the specifications of Intel® Ethernet Controller I210-IT
Ordering Code - WGI210IT
https://ark.intel.com/content/www/us/en/ark/products/64402/intel-ethernet-controller-i210it.html
With this, we'd like to check if you still have additional questions or clarifications on this query. If yes, feel free to let us know and we will be glad to check on it.
We will follow up after 3 business days in case we don't hear from you.
Crisselle C.
Intel® Customer Support
Donato
Hello Crisselle,
since the last time when we were looking for a PIN to PIN compatible alternative and the WGI210IT is not, something changed.
We so decided to change our gerbers but in the meanwhile our suppliers run out of stock of WGI210IT, it will be available in a year and half from now.
That's why I asked again.
Anyway thanks for the reply, the post can be closed.
Thanks and regards,
Donato
CarlosAM_INTEL
Hello, @Donato:
Based on the information that you have mentioned, we suggest addressing your question by filling out the form stated on the following website:
https://plan.seek.intel.com/SMARTForm_ICS
@CarlosAM_INTEL.
Caguicla_Intel
Hello Donato,
Thank you for the swift response.
Before we proceed with closure as per your request, we will try to check this query with our engineers for additional recommendation. Please expect an update no later than 2-3 business days.
Hoping for your kind patience.
Crisselle C.
Caguicla_Intel
Hello Donato,
Thank you for the patience on this matter.
We already escalated this request and have been advised that since this involves design inquiry as you are looking for pin to pin compatible alternative, please be informed that this will be best answered by our Embedded Connectivity Support team. We will help you to move this post to the designated team for further assistance. Please feel free to contact us if you need assistance from Ethernet support team.
Crisselle C.
