Embedded Intel Atom® Processors
Technological Conversations about Intel Atom® Hardware, Software, Firmware, Graphics
1224 Discussions
Does IEGD 10 support XP Pro SP2?
GGork
Hi All!
I know that Intel states that IEGD 10.x should work under XP SP3.
Will it work correctly under XP SP2?
Georgy
Kirk_B_Intel
There are no driver changes for graphics drivers between SP2 and SP3 so a driver should work on either (and does in my personal experience). We only VALIDATE with SP3 and although there is always a possibility that there is an issue on SP2 that we do not see on SP3 however that is HIGHLY unlikely for the graphics driver. SP2 is not POR for us so SP2 specific issues (if any) would not have a high priority for us. In a case like that the answer would likely be "update to SP3".
Hope that helps.
Kirk_B_Intel
Hope that helps.
JBell6
GEORGY, my experience is that XP will work, but the system will fail to resume after standby, forcing you to reboot. Kurt is pursuing this problem in another thread. I'd be interested to know if you experience the same problem as may others have reported.
RDool1
I agree with the previous replies, it should work fine with SP2, but in terms of official support, i dont know whether you need to have SP3 running.
However, one more thing to check is the Errata for IEGD which can be downloaded from:
https://premier.intel.com/premier/ProcessDownload.aspx?src=d&fl_id=11255 https://premier.intel.com/premier/ProcessDownload.aspx?src=d&fl_id=11255" rel="nofollow" target="_blank">https://premier.intel.com/premier/ProcessDownload.aspx?src=d&fl_id=11255
All the best,
Kind Regards,
Aryan.
