Embedded Intel Atom® Processors
Technological Conversations about Intel Atom® Hardware, Software, Firmware, Graphics
1224 Discussions
FPT tool error uner Linux for E3900
Yingwen001
When I use FPT tool to update flash on E3900 system(ApolloLake) on Ubuntu 18.04with kernel version 5.4.0-42 ,  It fails with hit " Time out waiting hardware to become available" error message.  Please refer following screen shot. And also I dump TxTInfo as below as well.
Please help to check source code what is meaning of this error message.
---------------------------------TxT info -------------------------------------------
Intel(R) TXEInfo Version: 3.1.94.3107
Copyright(C) 2005 - 2023, Intel Corporation. All rights reserved.
Intel(R) TXE code versions:
BIOS Version                                 UPBOARDA.X64.0071.D01.2309072336
Vendor ID                                    8086
PCH Version                                  D
FW Version                                   3.1.94.3086
Security Version (SVN)                       3
Number of IFWI Modules                       4
IFWI Module Name/Version
                                             FTPR.man   Version: 3.1.94.3086
                                             PMCP.man   Version: 0.1.0.0
                                             SMIP.man   Version: 3.1.94.3107
                                             IUNP.man   Version: 0.0.0.0
FW Capabilities                              0x31101040
        Intel(R) Capability Licensing Service - PRESENT/ENABLED
        Protect Audio Video Path - PRESENT/ENABLED
        Intel(R) Dynamic Application Loader - PRESENT/ENABLED
        Intel(R) Platform Trust Technology - PRESENT/ENABLED
Last TXE reset reason                        Power up
Host Read Access to TXE                      Enabled
Host Write Access to TXE                     Enabled
Host Read Access to EC                       Enabled
Host Write Access to EC                      Enabled
SPI Flash ID 1                               EF6018
SPI Flash ID 2                               Not Available
BIOS boot State                              Post Boot
Re-key needed                                False
Capability Licensing Service                 Enabled
OEM Tag                                      0x00000000
Slot 1 Board Manufacturer                    0x00000000
Slot 2 System Assembler                      0x00000000
Slot 3 Reserved                              0x00000000
EPID Group ID                                0x1205
Keybox                                       Not Provisioned
Crypto HW Support                            Enabled
Replay Protection                            Not Supported
Replay Protection Bind Counter               0
Storage Device Type                          SPI
Replay Protection Bind Status                Pre-bind
Replay Protection Rebind                     Not Supported
Replay Protection Max Rebind                 0
Intel(R) PTT Supported                       Not Supported
Intel(R) PTT initial power-up state          Disabled
PAVP Supported                               Yes
Integrated Sensor Hub Initial Power State    Disabled
End of Manufacturing Enable                  No
Post Manufacturing NVAR Config Enabled       No
Protect BIOS Environment                     Disabled
CPU Debugging                                Enabled
BSP Initialization                           Enabled
Measured Boot                                Disabled
Verified Boot                                Disabled
OEM Public Key Hash FPF                      Not set
OEM Public Key Hash UEP                      1405A8A4EB1C8AC251197D85961409FF15FDCD23D325CCDD88D2175CDE3B2736
OEM Public Key Hash TXE FW                   1405A8A4EB1C8AC251197D85961409FF15FDCD23D325CCDD88D2175CDE3B2736
                                             FPF                 UEP                 TXE FW
Boot Guard Profile                           Not set             0 - Legacy          0 - Legacy
Key Manifest ID                              Not set             0x1                 0x1
PTT                                          Not set             Enabled             Enabled
UFS Boot Source                              Not set             Disabled            Disabled
EMMC Boot Source                             Not set             Disabled            Disabled
SPI Boot Source                              Not set             Enabled             Enabled
LED Indication                               Enabled             Disabled            Disabled
DnX                                          Not set             Enabled             Enabled
OEM ID                                       Not set             0x0                 0x0
OEM Platform ID                              Not set             0x0                 0x0
SOC Config Lock                              Not set             Not set             Not set
RPMB Bind Counter                            0x0                 0x0                 0x0
RPMB Migration Done                          Not set             Not set             Not set
Persistent PRTC Backup Power                 Exists              None                None
Allow OEM Signing of DAL Applets             No                  No                  No
EK Revoke State                              Not Revoked         Revoked             Revoked
CSE SVN                                      3                   3                   3
OEM Key Manifest SVN                         0                   0                   0
Ucode SVN                                    0                   0                   0
                                             GPIO
                                             PMIC2 to I2C
                                             No GPIO Configured
                                             PMIC to SVID
                                             Community       Pin        Function        Interrupt
Clock                                        North           77         Native1         No
Data                                         North           76         Native1         No
Alert                                        North           75         Native1         No
                                             END of GPIO
--------------------------------------------------FPT under Linux --------------------------
Jaime_Lizarme
Hello @Yingwen001 ,
The Embedded Apollo lake CPU has just reached the End Of Interactive Support; that being said I would suggest using FPT under UEFI or Windows environment, if that still fails you might want to reach your BIOS vendor and ask for a proprietary BIOS flashing tool.
Jaime L.
