Embedded Intel Atom® Processors
Technological Conversations about Intel Atom® Hardware, Software, Firmware, Graphics
LH8066803102701 Spec code
isagani
Dear Support,
Please help me check for the part number LH8066803102701. They have two spec code which are SREKA & SR33Q.
Kindly advise what is the difference between the spec code and if they can be used as replacements to each other. Thanks
CarlosAM_INTEL
Hello, @isagani:
The SR33Q Spec Code is related to B1 stepping, and the F1 stepping is associated with the SREKA Spec Code, as you may confirm in the image that you have attached and the following website:
https://www.intel.com/content/www/us/en/products/sku/96486/intel-atom-x5e3930-processor-2m-cache-up-to-1-80-ghz/ordering.html
In order to answer your last question, you need to update your account to the premier option. You should fill out the form stated on the following website:
https://www.intel.com/content/www/us/en/forms/developer/premier-registration.html
You should use a business email address to evade any inconvenience. Please avoid the free email provider's address (such as the provided by Hotmail, Gmail, Yahoo, or others).
@CarlosAM_INTEL.
isagani
Hi Carlos,
Good day,
My email address is isagani@fcl-ic.com and this is my business/company email address.
Please help me check for the part number LH8066803102701. They have two spec code which are SREKA & SR33Q and Stepping F1 & B1 respectively?
Kindly advise what is the difference between the spec code and and Stepping F1 & B1 respectively, can they be used as replacements to each other.
Link>>
CarlosAM_INTEL
Hello, @isagani:
Thanks for your update.
It seems that you do not understand the last part of my previous communication.
You need to have a premier account to help you.
You need to fill out the form stated on the following website to update your profile:
@CarlosAM_INTEL.
isagani
Hi Carlos,
Yes, I understand, but I tried to register and I am having problem to proceed.
There's no button for "Next: Verify" to continue and there's a note "Email is already registered.
Please let me know how to proceed.
CarlosAM_INTEL
Hello, @isagani:
The information stated on the following website may help to solve your account problems:
https://www.intel.com/content/www/us/en/support/topics/sign-in-faq.html
@CarlosAM_INTEL.
isagani
Hi, @Carlos:
CarlosAM_INTEL
Hello, @isagani:
Thanks for your reply.
You need to follow our last suggestion stated in our communication of June 23rd to answer your questions stated in your last communication.
@CarlosAM_INTEL.
isagani
Hi Carlos,
As per my previous reply, I cannot proceed on your request.
I do not understand why you keep on asking me to register using company/ business email address whereas email address provided to you is isagani@fcl-ic.com
Please refer to the photo for reference. Also link below you provided cannot help.
Can you answer my question or not?
regarding the difference between the spec code SREKA & SR33Q and and Stepping F1 & B1, can they be used as replacements to each other.
CarlosAM_INTEL
Hello, @isagani:
It seems that you do not understand our previous suggestion.
You have a basic account.
We suggest updating it to privileged because the information that may answer your last question is included in the documentation that cannot be shared with basic profile customers.
Due to this fact, please update your profile to give you the information that may help you.
@CarlosAM_INTEL
