hidden text to trigger early load of fonts ПродукцияПродукцияПродукцияПродукция Các sản phẩmCác sản phẩmCác sản phẩmCác sản phẩm المنتجاتالمنتجاتالمنتجاتالمنتجات מוצריםמוצריםמוצריםמוצרים
Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
1289 Discussions
Does the DDR Interface/Memory Controller of Tiger Lake UP3 i7-1186GRE Support ECC?
lo3
I am conducting some research on the Intel Tiger Lake UP3 i7-1186GRE processor, specifically regarding its memory controller. I would like to know if the DDR interface/memory controller of this processor supports ECC (Error-Correcting Code) memory.
I haven’t been able to find any clear references to this in Intel's documentation or related technical materials. To avoid using incompatible memory, I would like to confirm whether this processor supports ECC memory. Additionally, if possible, I would appreciate any details on whether there are specific hardware or software requirements to enable ECC functionality.
Thank you for your help! Looking forward to your response!
CarlosAM_INTEL
Hello, @lo3:
The answer to your question is stated in the last row of the Memory Specifications section of the following website:
https://www.intel.com/content/www/us/en/products/sku/208082/intel-core-i71185gre-processor-12m-cache-up-to-4-40-ghz/specifications.html
@CarlosAM_INTEL.
lo3
Dear CarlosAM_INTEL,
Thank you for your response.
I have reviewed the information on the website you provided and noted that the 1185GRE supports memory ECC. However, in document #575683 (as shown in the image below), it appears that ECC support is only available for the H-series. Could you kindly confirm again whether the UP3(i7-1186GRE) supports memory ECC?
Additionally, could you clarify what "N/A" means in the context of the LPDDR4x listed in the image below?
Looking forward to your confirmation.
CarlosAM_INTEL
Hello, @lo3:
Thanks for your reply.
The information that may help you can be found in the document stated in the following website:
 https://cdrdv2.intel.com/v1/dl/getContent/621597
In case you have problems with the provided website, you should request help by filling out the form stated on the following website:
https://www.intel.com/content/www/us/en/forms/support/my-intel-sign-on-support.html
@CarlosAM_INTEL.
