Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
1417 Discussions
galileo, Function failed: do_kernel_configme
wmirr
Hi, I am bulding Galileo's kernel, with Board_Support_Package_Sources_for_Intel_Quark_v1.0.0.7z, download from :
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=23197 Download Center
Couple of days ago, I can not run setup.sh, error like:
Running: git init
Initialized empty Git repository in /home/watermirror/galileo/meta-clanton_v1.0.0/poky/.git/
Running: git remote add origin git://git.yoctoproject.org/poky
Running: git fetch origin --depth=3 tags/dylan-9.0.2:tags/dylan-9.0.2
fatal: The remote end hung up unexpectedly
fatal: protocol error: bad pack header
Traceback (most recent call last):
File "setup/gitsetup.py", line 131, in
main()
File "setup/gitsetup.py", line 117, in main
run_command('git fetch origin --depth=%s %s' % (opts.depth, fetchspec))
File "setup/gitsetup.py", line 65, in run_command
subprocess.check_call(command, shell=True)
File "/usr/lib/python2.7/subprocess.py", line 511, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command 'git fetch origin --depth=3 tags/dylan-9.0.2:tags/dylan-9.0.2' returned non-zero exit status 128
the error not came out last night, I exeucte setup.sh sucessfullly. But when i ran
bitbake image-full
new errors comming:
ERROR: Function failed: do_kernel_configme (see /home/watermirror/galileo/meta-clanton_v1.0.0/yocto_build/tmp/work/clanton-poky-linux-uclibc/linux-yocto-clanton/3.8-r0/temp/log.do_kernel_configme.2600 for further information)
ERROR: Logfile of failure stored in: /home/watermirror/galileo/meta-clanton_v1.0.0/yocto_build/tmp/work/clanton-poky-linux-uclibc/linux-yocto-clanton/3.8-r0/temp/log.do_kernel_configme.2600
Log data follows:
| DEBUG: Executing shell function do_kernel_configme
| [INFO] doing kernel configme
| [INFO] Configuring target/machine combo: "standard/clanton"
| [INFO] collecting configs in ./meta/meta-series
| mv: target `3.8.7' is not a directory
| creation of pre-processed config data failed
| config of "standard/clanton" failed
ERROR: Task 348 (/home/watermirror/galileo/meta-clanton_v1.0.0/meta-clanton-bsp/recipes-kernel/linux/linux-yocto-clanton_3.8.bb, do_kernel_configme) failed with exit code '1'
NOTE: Tasks Summary: Attempted 2668 tasks of which 2651 didn't need to be rerun and 1 failed.
I should I do?
Jorge_I_Intel
Dear watermirror,
I would like to invite you to post this thread here: https://communities.intel.com/community/makers Space: Makers | Intel Communities where there is a lot of discussions already going around about this and similar topics.
I am the community manager for that forum.
Rgds,
Jorge
