We are using an off the shelf, industrial system built by a well known manufacturer. The application is an AI based Machine Vision solution. The system uses an i7-1370PRE processor. We are running a large set of performance tests and are carefully monitoring CPU temperature. All cores are operating within a range of 90C to 65C. Well within spec.
But at around 90C core temp, we see normal operation of the CPU but excessive throttling of the GPU. Our machine learning model uses the GPU very effectively but the high rate of throttling at just 85C was shocking and results in a huge impact to our performance numbers.
Our only recourse was to down clock the GPU from 1.4GHz to 1GHz while keeping the CPU clock at 1.9GHZ. Note that we are not running in turbo mode.
Is there any solution or workaround to the GPU throttling at 90C core temp?
Hello machine_vision,
Base on your inquiry, we have specific forum for these issues or inquiries. I will be transferring this thread for faster response.
Please wait for their reply within 1 to 2 business days.
Michael L.
Hi Scott, Good question. Our only means of verification that the GPU is being throttled is to monitor the temperature & performance of that core. Then to down-clock the GPU till we see consistent performance. When we do this, we do see (in correlation to the down-clocking) that specific core temp reducing. Happy to post all the detail graphs. If you can provide us with a more precise process for confirming GPU throttling, we can check.
You could use an app like ThrottleStop to verify whether the cause is Temperature, Current or externally (VRM, etc.) related.
Thank you. As a note, we run Linux, Ubuntu 22.04. Is ThrottleStop available for Linux?
I honestly don't know. Not a Linux expert.
Sorry,
Appears to be windows only:
https://www.techpowerup.com/download/techpowerup-throttlestop/
Thank you
Looks like there is a Linux version:
https://github.com/agoose77/throttlestop
Hello @machine_vision,
You may try with the latest driver for Linux:
https://dgpu-docs.intel.com/installation-guides/index.html
![](/skins/images/8B5EA638CA3587CA763EE9EF53643DD4/responsive_peak/images/icon_anonymous_message.png)
