Embedded Server
Consolidate Considerations of Intel® Xeon and Atom server Hardware, Firmware, Software, and Tools
Annunci
306 Discussioni
Why is that the performance of bigger frame can't achieve line rate while using DPDK
Dipendente
3.283Visualizzazioni
Hi all,
We have a platform like this:
CPU: Intel Xeon E3-1275v3 @3.5Ghz
DRAM: Samsung DDR3 4G * 2
OS: RHEL 6.4 x64
NIC: XL710
Lan driver: i40e-1.4.25
We used this platform to run smarbit RFC2544 testing with 'testpmd' of DPDK, and got this result:
And here is a result that didn't run with DPDK.
My question is,
Why does the performance/throughput can not to achieve line rate (100%) while using DPDK
I talk about bigger frame, such as 1280B、1518B.
btw, we using DPDK 2.2.0 and the testing command is:
./testpmd -c 0x3c -n 4 -- -i --nb-cores=4 --portmask=0xf
PS.
We did not put a acceptable frame loss in our smartbit setting, just 0%.
and we checked details of the smartbit test report, there is few frame loss (~0.001%) while running with 100% loading, like below:
Thanks and regards,
Leo
6 Risposte
CarlosAM_INTEL
Moderatore
2.282Visualizzazioni
Hello Leo_Yeh,
Thank you for contacting the Intel Embedded Community.
The first and third image of your previous communication show us the following advice:
Could you please re-post them?
By the way, could you please let us know the Smarbit RFC2544 version related to this condition? Please try to reproduce this situation with the version 1.0 or greater and let us know the results.
Thanks in advance for your cooperation.
Carlos_A.
Dipendente
Hi Carlos_A,
I did a re-edit, please check it out.
And, I don't understand what you mean "Smarbit RFC2544 version", where can I find it?
you mean firmware version of Smartbit?
Thanks and regards,
Leo
CarlosAM_INTEL
Moderatore
Hello Leo_Yeh,
Thanks for your reply.
Correct, we refer to the Smarbit.
Please give us the requested information.
Thanks again for your collaboration.
Carlos_A.
Dipendente
Hi Carlos_A,
The version of Smartbit is 4.56
Thanks and regards.
Leo,
CarlosAM_INTEL
Moderatore
Hello Leo_Yeh,
Thanks for you reply.
Please review as a reference the forum http://dpdk.org/ml/archives/dev/2015-March/016043.html [dpdk-dev] issues with packets bigger than 1500 bytes.
By the way, it is important to let you know that in order to help you with your DPDK questions, they should be addressed to the channels listed at the http://dpdk.org/ml DPDK Mailing Lists.
We hope that this information is useful to you.
Carlos_A.
Dipendente
Hi Carlos_A,
Thanks a lot.
I will register there.
Thanks and regards.
Leo,
Rispondere
